need help try to pass emissions so i can drive codes 41 54 65
Old Jul 18, 2006 | 10:12 PM
CHAZegHATCH's Avatar
Default need help try to pass emissions so i can drive codes 41 54 65
ok iv got a 99 civic cx hatch with a 2000 h22a4 in it runs great with obd2b to obd1 harness and a chipped p28 with out a cel, i plugged up a stock p28 still no cel light i pluged up a 99civic si ecu so the it would read at the emissions place and i have codes;
41 Primary oxygen sensor heater
54 CKF - crank fluctuation sensor
65 Secondary oxygen sensor heater
i am hoping that 54 willl go away with 41 i checked both the grounds and thy are good and i have battery voltage on one wire wat is the signale voltage if some one could tell me wat the each wire color + wat the correct voltage should be that would help and i have a o2 simulator for 65 any info would help! got to pass so i can have it as my daylly driver
Old Jul 18, 2006 | 10:24 PM
Default Re: need help try to pass emissions so i can drive codes 41 54 65 (CHAZegHATCH)
come on need help from the h22 guys
Old Jul 19, 2006 | 08:59 AM
morning bump
Old Jul 19, 2006 | 09:30 AM
ok i was just out side lookin at my obd1 to obd2b harness there is no wire going in to d14-PHO2S O2 sensor, heated 02 sensor Signal, in fact there is a wire coming out that is labled NB out wat the hell is NB out and it is just taped off going nowhere, how is that posible for it to fun like that with no codes
Old Jul 20, 2006 | 10:08 AM
if i could fix 41 would that fix 54 has that ever happened to any one?
Old Jul 20, 2006 | 10:13 AM
Andres-eh2's Avatar
do u know if 2000 h22's have a CKF
Old Jul 20, 2006 | 07:01 PM
Default Re: (Andres-eh2)
lol, is there a obd2b civic ecu that dosint have a CKF sencer
Old Jul 20, 2006 | 07:47 PM
fastrepoman's Avatar
not sure if this can be done on a honda but we regularly do it on gm stuff why not just go into the pcm progrmming files and remove these codes from your operating system.
Old Jul 20, 2006 | 08:18 PM
Default Re: need help try to pass emissions so i can drive codes 41 54 65 (fastrepoman)
dont thank that will work
bobcollege
15
Mar 22, 2018 10:12 PM
moejoepotatoe
16
Dec 10, 2012 07:49 PM
sohc_ef2
Sep 29, 2012 05:34 PM
Honda-Hooligan
Jun 21, 2010 02:42 PM
JDMBOOGERHATCH
Dec 3, 2004 06:49 AM
