Help! Bad Mechanic
Old Jul 18, 2006 | 09:16 PM
BananaSi's Avatar
Default Help! Bad Mechanic
I'm posting this for a friend. He's only 16 and just recently got his car, a 97 4dr accord se. What happened was he ran into a curb with the passenger front tire. Took it to a mechanic who "fixed" it, even had to straighten some of the chasis.
Whats happening now is that even after an alignment and new tires, the car still veers towards the passager side. There is also a "whirring" noise coming from the front passenger wheel (my observation). It increases in noise and frequency with speed.
Any ideas? Any help would be greatly appreciated. I'd like more information before going with him and talking to the mechanic.
Old Jul 19, 2006 | 05:51 AM
v4lu3s's Avatar
RTFM
Basically it doesnt matter what the problem is because the problem has not been fixed. I would even consider going to a body/frame shop to have them take a look at at it and get an estimate as well.
Old Jul 19, 2006 | 06:14 AM
Ross 2.0's Avatar
In a Junkyard near you.
sounds like a broken wheel bearing atleast
Old Jul 19, 2006 | 06:51 AM
londonsupra's Avatar
inspect all the suspension compoents..
look for a busted *** ball joint or play in it..
also look for cracked spring blown shock bad wheel bearing like moo said.. make sure everything is in order first.
once you check that then inspect the frame visually... after that possibly take it to another alignment place that will do the job correctly.. ask around to find out who is good in your area.
Old Jul 19, 2006 | 08:49 AM
EASY101's Avatar
* B A N N E D *
what these guys said and/or the frame is still not straight.
Old Jul 19, 2006 | 01:23 PM
honda4674's Avatar
just out of curiosity what did they say they fixed id take it back to them and try and see if i could get it straigtnd out seems like BS to me
Old Jul 19, 2006 | 08:04 PM
pos_cd5's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a broken wheel bearing atleast</TD></TR></TABLE>
yup, thats what the whirring noise probably is. did you guys ask for a spec sheet for the alignment? something has to be still bent, i had this problems like...4 times...what did he fix? the very least it should be control arm and maybe radious rod
jkalex05
Nov 24, 2009 11:32 AM
alexthegrinch
Jul 30, 2008 06:59 PM
SurJones
Apr 24, 2007 08:19 AM
dRuNkEnMoNkEy97
Sep 27, 2006 08:56 PM
LoserKid
Suspension & Brakes
Aug 18, 2005 09:15 AM
