A/F ratio wire?
yeah, so i got a a/f ratio gauge(free had the dash out for paint so i said wth. anyways) got a power and a ground wire and a wire run to the o2 sensor, now which wire do i splice into? think i got 2 black, a green and a ?white? not sure about the white, but i know i have 4 wires, which on do i use? hit me back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atomikcoupe95 »</TD></TR><TR><TD CLASS="quote">it would be the white wire
Is it still the white wire on a 5 wire (wideband) o2 sensor?
</TD></TR></TABLE>Is it still the white wire on a 5 wire (wideband) o2 sensor?
4-wire O2
black wires - O2 heater
green - O2 signal ground
white - O2 signal
the A/F gauge uses the white wire.
5-wire O2 sensor
you can not monitor using a standard A/F gauge.
white - O2 signal
5-wire O2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">no use if you don't have a wideban, just a stupid eratic light show.</TD></TR></TABLE>
True.
The reasoning behind this is that the stock 02 sensor uses a 0-1v sensor. The wideband that I have (a techedge) uses a 0-5v sensor, effectively multiplying the spectrum that you can see by 5. With a narrowband you have a very very small window that you can actually see/use.
True.
But it's still somewhat accurate. Not dead on, but will give you a ball park. For example, giving it WOT and the meter reading all the way green. Which is good. The standard a/f ratio gauge with a factory O2 is not completely useless. Good info though, i've had an a/f gauge sitting in the closet that i've been waiting to put in.
the problem with the OEM O2 is that anything over 14.0:1 and it's full tilt rich. So at WOT you have no idea if your at 14:1 or 10:1.
I had one for a while. I liked it in a way, I hit a spot in my map where it went lean while pushing so I let off quickly and richened it up a little in that area.
If I didn't have the gauge I wouldn't have known and who knows what would have happened over time.
I have a full time wideband now.
thanks, imma proly get a wideband when i get my swap, juswt got a stock z6 now, but i ahve invested over 4500 dollars in this car and the motor has YET to be touched. problem i have now is that the gauge is a piece i believe. the lights come on, but they start at rich, then work their way around to lean, bu none of the lights ever go out, i havent driven the car yet b/c its not done, and im not takin it out till it is, just wired everything up(jdm mirrors, gauges, jdm foglights etc) but the guage isnt working, imma go buy a new one and see if that works if it doesnt work any better when i finally drive it. thanks for your info
mdrouillard1983
Jun 1, 2014 06:15 PM
wickedxboi
Mar 22, 2003 01:51 PM
