Wiring Dual Halo Reverse Gauges 97 Honda Accord
Old Jul 18, 2006 | 07:25 PM
LogDesigner's Avatar
Default Wiring Dual Halo Reverse Gauges 97 Honda Accord
While learning from my first mistake of removing the needles from the cluster. Where would be a good place to tap into a good hot and negative for the new gauges? I have three wires conecting to my factory dimmer switch. Black, Solid Red, Solid Red w/Black Stripe. Anyone know which wires I need to tap into? I am sure black to black. Just trying to figure which red to connect to. I am sure one is a constant hot from the switch going to the dimmer. Just wanting to connect to the right wire so when I turn the lights on the guages light up.
Old Jul 20, 2006 | 08:37 AM
Intense3.2's Avatar
Default Re: Wiring Dual Halo Reverse Gauges 97 Honda Accord (LogDesigner)
What did you just say..?
Old Jul 20, 2006 | 01:10 PM
Default Re: Wiring Dual Halo Reverse Gauges 97 Honda Accord (Intense2.2)
Three wires at the factory dimmer switch, which wire do I connect the hot wire from the reverse gauges to? Solid red or Red w/Black stripe? I don't need a constant hot, just othe one that will be hot when I turn my parking/headlights on.
LaTe ApEx
16
Aug 30, 2021 11:20 AM
rugimpy
Audio / Security / Video
40
Dec 2, 2009 06:51 AM
greenblurr93
Lighting
Oct 18, 2007 08:01 AM
dansaleen_04
Mar 22, 2006 04:40 AM
IDI2IEIAIVIS
13
Feb 23, 2003 09:22 AM
