(ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP
Old Jul 18, 2006 | 06:52 PM
kewbee7's Avatar
Default (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP
Electrical Load Detector (ELD) off a 99-00 civic hb.
where is this or how can i fix it. i think its makin my lights flicker and dim. i read that it may also make my speedo go all crazy which itpretty much does.
where is this amd how can i fix this problem, got emissions next week.
or should i just try puttin in another fuse bos in the engine bay.. since the eld is built into that...
Old Jul 18, 2006 | 07:11 PM
JimBlake's Avatar
Default Re: (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP (kewbee7)
The ELD is built into the under=hood fuse box, so you have to replace that. But first, check to see if there's a wiring problem between that ELD & the ECU.
I don't think the ELD would cause the speedometer to go flaky. Check the vehicle-speed sensor (VSS) on the tranny.
Old Jul 18, 2006 | 10:04 PM
kewbee7's Avatar
Default Re: (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP (JimBlake)
i already have changed checked the speedo with a working one and it didnt do anything. and also changed in a wrkin gauge cluster, nothing... i have all the part since i wrk at a wrkecin yard, just dont know where the problem is at..
Old Jul 18, 2006 | 11:18 PM
97hb's Avatar
Its in the alternator.
Old Jul 19, 2006 | 12:20 AM
kewbee7's Avatar
Default Re: (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP (97hb)
imma try that tomorrow...
Old Jul 19, 2006 | 05:22 AM
MaddDogg49's Avatar
look under the dash and see if the alt fuse is blown
i had this same problem and it was cause i had halos wired into my lights... i uped the alt fuse and wired the halos into the parking lights and it hasnt done it since
Old Jul 19, 2006 | 05:27 PM
kewbee7's Avatar
Default Re: (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP (MaddDogg49)
nvmd guys thanks, alternater/sp sensor fuse was blown... its fixed everything!
Old Jul 19, 2006 | 07:06 PM
v4lu3s's Avatar
RTFM
it is going to blow again eventually
udner the engine where the harness goes between the manifold and the brace it has probably rubbed a spot where the wires can ground to teh brace. usually taping it up will solve this problem.
FillDirty
Jul 14, 2008 12:39 PM
wjelmer
Nov 3, 2006 01:50 AM
mark2379
Sep 8, 2006 11:46 AM
Bo0sted4Do0r
Apr 27, 2006 09:38 AM
2K1 BLK ITR
Nov 6, 2001 12:33 PM
