Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 CRV brake?? grinding
Old Jul 18, 2006 | 06:38 PM
sjthaxter's Avatar
Default 2000 CRV brake?? grinding
When stopping we get an intermittent grinding noise from the brakes. I can't pin it down to one wheel, so am not positive it is brake noise. It is worse with the wheels turned either way from straight ahead. I did read about the differential lube problem on another post and wonder if this could be related. It has 115K miles.
Thanks,
John & Sue
Old Jul 19, 2006 | 03:40 AM
Ross 2.0's Avatar
In a Junkyard near you.
i doubt a differential issue since your just stopping.
Definately have it checked out. What brand of brake pads are on it?
Modified by MooGoCow3 at 7:56 AM 7/19/2006
Old Jul 20, 2006 | 07:07 PM
sjthaxter's Avatar
Default Re: (MooGoCow3)
Thanks MooGoCow, the pads are ceramic, installed a couple of years ago by Meineke. They look good, with enough surface left to last a while. I had the rears checked about a year ago, and they were OK then. I can't get the drums off to look at them, so will probably take it someplace to be looked at.
Regards,
John & Sue
Old Jul 21, 2006 | 06:55 AM
Ross 2.0's Avatar
Default Re: (sjthaxter)
The problem is those ceramic brake pads. In all honesty the best brake pads to use are the honda pads, they stop good for a daily driver, they are pretty much dust and noise free too.
philkehn
22
Mar 8, 2023 11:11 AM
CerealKiller1117
Sep 18, 2003 10:05 PM
sean96gsr
Feb 25, 2003 10:57 AM
garados
Oct 15, 2002 03:39 PM
KingJeff
Sep 9, 2002 10:48 AM
