gsr sway bar endlinks too far away from lca
Old Jul 18, 2006 | 04:34 PM
byronl's Avatar
Default gsr sway bar endlinks too far away from lca
i just installed a gsr sway bar with omnipower rear lower control arms on my ej1. I lowered the car down so i can bolt up the endlink to the lca but i notice that it is very far apart from each other, the bolt that i got from the dealer does not fit. I've never dealt with sway bars before so iono if i installed it wrong or do i just go to home depot get longer bolts and bolt it on?
Old Jul 18, 2006 | 04:45 PM
BlueIntegraBoy's Avatar
Default Re: gsr sway bar endlinks too far away from lca (byronl)
Swivel the sway bar so that the bolt comes closer to the LCA. Although bolted to the subframe (hope you didnt tighten yet), you can still swivel it.
Old Jul 18, 2006 | 05:09 PM
byronl's Avatar
Default Re: gsr sway bar endlinks too far away from lca (BlueIntegraBoy)
that works! i got one side in, now imma go get the other side in. I then tighten everything down while the car is on the ground correct?
Old Jul 18, 2006 | 05:35 PM
yes
Old Jul 18, 2006 | 05:54 PM
byronl's Avatar
cool, it's done, thx alot but now my exhaust pipes rattle against it, i'll take it to a muffler shop in the morning to get that fixed.
96Formula6spd
Jun 9, 2011 05:13 PM
FRKWOO
Feb 22, 2009 05:56 AM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
shotgun2224
Feb 18, 2008 10:10 PM
dc4teg95
Apr 30, 2007 09:30 AM
