Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
B1 service, how much should it run?
Old Jul 18, 2006 | 04:04 PM
dpao6's Avatar
Default B1 service, how much should it run?
Hi everyone. At 11,5XX miles, my car is due for a B1 service, according to the dashboard. Dealership said it would run me around $150. Has that been the case for you guys as well? I'm a little disappointed because, while the B1 service includes inspections to parts such as tie rods, topping off fluids, even the exhaust, etc etc, was some of this necessary for a car this new?? I can see that doing a major check up is good at any mileage, but if it's gonna run the consumer $150 every other service interval, then this kind of defeats why I wanted a Civic in the first place, which was ease of maintenance and ownership. How's it been for you guys? I'm over here scratching my head at the thoght of paying $150 or more (if more numbers are present on the maintenance minder) every 10k miles.
ps. 1 is for rotate tires btw. Not a big fan of that every 5k miles either. But i guess it wouldn't hurt, they'll just end up charging me more for something I can do at home basically.
Modified by dpao6 at 8:17 PM 7/18/2006
Old Jul 18, 2006 | 04:26 PM
kevinm30's Avatar
Default Re: B1 service, how much should it run? (dpao6)
I never even heard of that. In my opinion its a bunch of bs. They will probally spend 5 minutes lookin at your car and charge your the $150, and say they did a few things, but probally did nothing. My car will probally never go back to the dealer, unless i go to traded it in lol.
Old Jul 18, 2006 | 04:56 PM
Ross 2.0's Avatar
In a Junkyard near you.
it's just a regular oil change with the filter and a tire rotate. I would do it at home cheaper. Good job on actually using the maintnence minder though.
Old Jul 19, 2006 | 05:55 AM
Nohawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm30 &raquo;</TD></TR><TR><TD CLASS="quote">I never even heard of that. In my opinion its a bunch of bs. They will probally spend 5 minutes lookin at your car and charge your the $150, and say they did a few things, but probally did nothing. My car will probally never go back to the dealer, unless i go to traded it in lol.</TD></TR></TABLE>
Yeah, that is all BS. Rotate tires around every 10,000 miles (if you want). That is all preference. As far as all the other checks. You check your own fluids, that is extremely easy to replace if needed. You do not need to check everything else if you have not heard any abnormal noises or other indicators coming on.
Old Jul 19, 2006 | 06:27 AM
Sam1am26's Avatar
Default Re: B1 service, how much should it run? (Si 4 Life)
Just change your oil every 5000 miles and rotate your tires every 10k. Every 30k change all your major fluids and it will run forever. i work at honda and they won't even check any of the things listed.
Old Jul 19, 2006 | 12:43 PM
Hellzcivic's Avatar
I had a 2001 Civic DX. Put 130,000 miles on it and only changed the oil & filter every 5,000 to 6,000 miles and rotated the tires every 12,000.
The ONLY thing even had to replace was the tires (72,000) and Air cleaner (every 24,000).
It was the cheapest, most dependable car I ever owned in life, and I have been alive for almost 50 years.
Old Jul 19, 2006 | 01:45 PM
Nohawk's Avatar
Default Re: B1 service, how much should it run? (Hellzcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">I had a 2001 Civic DX. Put 130,000 miles on it and only changed the oil & filter every 5,000 to 6,000 miles and rotated the tires every 12,000.
Yeah, my 02 civic LX was good too, but I sold it at 44,000 miles for the new Si. Only changed oil, tires and air cleaner too.
Old Jul 19, 2006 | 02:34 PM
dpao6's Avatar
Good deal. Thanks everyone.
pcguy760
May 25, 2011 06:23 PM
dmfare
Dec 13, 2001 09:14 PM
