Check engine light question
Old Jul 18, 2006 | 03:06 PM
erikgsr's Avatar
New User
Default Check engine light question
Hey guys,
I just picked up a 92 Integra GS, and the check engine light does not light up when the ignition is turned on. I checked the fuses couldn't find the one for the CEL. Any one know where the fuse for the light is? I want to check the fuse before checking the bulb. Any help is appreciated.
Erik
Edit: already tried searching.
Old Jul 18, 2006 | 03:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: Check engine light question (erikgsr)
There is no specific fuse for the MIL. I would suggest pulling the cluster and checking the bulb first.
Old Jul 18, 2006 | 03:43 PM
-Todd-'s Avatar
Default Re: Check engine light question (Padawan)
They probably pulled out the light so you would'nt know the car was throwing a cel? Some shady people out there. Pull the cluster and check it out, might just be a blown bulb or might need one in it.
Old Jul 18, 2006 | 03:51 PM
erikgsr's Avatar
New User
Default Re: Check engine light question (-Todd-)
Thank guys, there is no question in mind that the ecu is throwing a code, the car failed emmisions terribly. I kind of suspected the previous owner either pulled the bulb or fuse. I just figured the fuse would of been easier, had there been one for the CEL. Ill check out the bulb tommorow.
Erik
Old Jul 18, 2006 | 03:58 PM
-Todd-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikgsr &raquo;</TD></TR><TR><TD CLASS="quote">Thank guys, there is no question in mind that the ecu is throwing a code, the car failed emmisions terribly. I kind of suspected the previous owner either pulled the bulb or fuse. I just figured the fuse would of been easier, had there been one for the CEL. Ill check out the bulb tommorow.
Erik</TD></TR></TABLE>
That sucks. All your other lights come on when you turn the key over? The guy I bought my car from pulled not only the cel bulb, but the abs bulb as well.
Old Jul 18, 2006 | 04:17 PM
erikgsr's Avatar
New User
Yeah all of the other lights are working.
tcyprusdc2
Mar 19, 2014 10:09 AM
ericrcan
Nov 24, 2012 07:54 PM
Cdeese910
Oct 25, 2012 07:56 AM
62maxx
Oct 25, 2006 03:45 PM
