STRIPPED LCA bolt
Old Jul 18, 2006 | 03:02 PM
TurdBlown Teg's Avatar
Default STRIPPED LCA bolt
like the title says its stripped where the shock meets the lca its stripped kinda bad. need some advice on getting it off. if anyone can help that would be great.
Old Jul 18, 2006 | 03:41 PM
skunked's Avatar
Default Re: STRIPPED LCA bolt (kevin716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin716 &raquo;</TD></TR><TR><TD CLASS="quote">like the title says its stripped where the shock meets the lca its stripped kinda bad. need some advice on getting it off. if anyone can help that would be great. </TD></TR></TABLE>
Get a grinder and get after it.
Old Jul 18, 2006 | 03:53 PM
Lan's Avatar
Lan
Default Re: STRIPPED LCA bolt (skunked)
Or a saw zawl
Old Jul 18, 2006 | 03:57 PM
Redemption's Avatar
I cut the the shock arms with a saw zaw then used a flame torch to burn the bushing to get the bolt. There is a big chance it has seized up there. The only problem its hard getting the new bushing in without a press.
That is if you dont care about ruining the shock
Old Jul 18, 2006 | 07:46 PM
atg1290's Avatar
Those bolts are a pain i used a saw zaw and a dremel....Took me about 6 blades for one bolt and a couple disc from the dremel, make sure your equiped!
Old Jul 18, 2006 | 08:12 PM
yeah i dont care soo much. but i just picked up the crapsman bolt strip things that should take care of it some guy said they work real well soo lets see if they do
2Point2EH2
Apr 25, 2006 10:36 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
Gunmetal_B20_Hatch
Aug 3, 2005 08:23 PM
GoQkRaCeR
Apr 24, 2004 05:40 PM
elwood
Apr 14, 2003 12:31 AM
