5 bolt exhaust gasket???????????
I'm having a hard time finding a ford 5 bolt exhaust gasket, and I'm wondering if it's really necessary, but I'd rather run one just incase. If someone could point me to an online store/ebay that has a 5 bolt turbo exhaust gasket, and if you guys are running a gasket. If you don't run a gasket, do you have an exhaust leak? I just spent the last 40mins searching and nothing, I'm frustrated and could use to help. thanks
RRE has one
i had a tiny leak
but used copper gasket spray the 2nd time and it seems fine now
http://www.roadraceengineering...s.htm
i had a tiny leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spicyEM1 »</TD></TR><TR><TD CLASS="quote">just use copper spray and it shouldent leak</TD></TR></TABLE>
So your saying if I spray a couple layers of copper onto the 5 bolt flange, then it will not leak? I was also thinking of using a donut gasket for the main 2.5 in DP opening, but the DP is 3". I was thinking of sandwiching a 3" donut between the flange and turbo, but thanks.
most ppl don't run one. i did before. i bought this sheet of gasket material, it was 15"x36". more than enough to make like 50 gaskets probably. hahaha. it was from napa, just tell them you want the material that goes between the turbo and downpipe. they can look it up.
