Question about car alarms
All right,when i bought my car it had this alarm that was pretty gay.When you activate it,rather than getting a "beep beep",it TALKS to you and says "SYSTEM ARMED" and when you de-activate it,it says "SYSTEM DISARMED",also when there's an intrusion it says "PROTECTED BY SECURITY SYSTEM!!STAND BACK!!"
It's embarassing as hell,luckily i found out how to activate it silently,but i was wondering if i can just replace the siren.Looking at ebay,most of them are dirt cheap
It depends on the alarm you have, if its just a voice module added to an alarm, then yes it should be easy, remove voice module and speaker and install a siren, or wire up the cars horn.
Can you find the alarm brain and get a make and model number off it?
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> It depends on the alarm you have, if its just a voice module added to an alarm, then yes it should be easy, remove voice module and speaker and install a siren, or wire up the cars horn.
94</TD></TR></TABLE>yeah,i have the manual right here actually It's a Hornet 720T..with BUILT IN VOICE!!!lol
FTL!
94</TD></TR></TABLE>yeah,i have the manual right here actually It's a Hornet 720T..with BUILT IN VOICE!!!lolFTL!
You can turn off the voice and replace it with chirps... http://www.directeddealers.com...T.pdf
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> You can turn off the voice and replace it with chirps... http://www.directeddealers.com...T.pdf
grrrrrr,it didnt work.I dissasembled the whole siren,i pulled a wire which i think is the constant from the fuse box and i couldnt find "the fuse".I followed their direction and it still wouldnt do it,the only thing i can think of is i didnt "power" down the system.Where the hell am i supposed to pull the fuse from the "fuse holder" so i can power it down?
fcm,
i need your help,lol,where would this "fuse" be?
94</TD></TR></TABLE>grrrrrr,it didnt work.I dissasembled the whole siren,i pulled a wire which i think is the constant from the fuse box and i couldnt find "the fuse".I followed their direction and it still wouldnt do it,the only thing i can think of is i didnt "power" down the system.Where the hell am i supposed to pull the fuse from the "fuse holder" so i can power it down?
fcm,
Disassembled the siren????, You do not have to disassemble the siren/module, turning the voice off is done in programing using the remote.
Did you not read the "operation settings learn routine" on page 7 of install guide I linked to you?
The fuse, [in-line] is on the red power wire, probably within a few inch's or so of the plug to the siren/module, however you do not need to "power down" the unit for programing.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">Disassembled the siren????, You do not have to disassemble the siren/module, turning the voice off is done in programing using the remote.
lol,yeah i couldnt find that fuse for anything
i did read it,step number one says if the system is not powered up go ahead and put the fuse in the fuse holder.If it's already powered up,power it down and back up for it to be able to go into learning mode or w/e.
so its on the red power wire?do you know what it may look like?the siren in the engine bay just has wires in a loom going in the cabin.
thnx
94</TD></TR></TABLE>lol,yeah i couldnt find that fuse for anything
thnx
All right i give up,it wont work.I dont know if that manual is for a NEWER 720T,but my little booklet says 1993 and im pretty sure taht damn voice guy is the only option
fcm,
do you think if i buy a new siren,he'll go away?
fcm,
Are you reading the same thing I am?
Top of page 7, [of the link I gave you] "operations settings learn routine"
To enter Learn Routine
1. Arm the system
2. Disarm the system
3. Press and hold Buttons I and II on the transmitter until the unit generates a long chirp. The long chirp is followed by a short chirp indicating feature one has been accessed in the operations settings learn routine.
4. Release the transmitter buttons.
Repeat steps 3 and 4 to advance to the next feature, Each time you advance a feature, the feature number you have selected will be indicated by the number of short siren chirps.
You need to hear 5 short siren chirps then press and release transmitter button II, the siren should chirp 2 times, [feature 5- Voice off].
You do not need to power down and up for programing, where are you reading that?
94
1. Arm the system
94
i say keep it!!!
is it one of those where u can program ur voice or somethin...
dude if u put a gay sounding voice as ur siren.. it would scare some ppl away...
and draw others...
and draw others...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 »</TD></TR><TR><TD CLASS="quote">Yeah,i've tried that like 10 times and it wouldnt work.It's all good until step 3,lol,the chirp never comes.I dont think there is a chirp
</TD></TR></TABLE> are you sure you are pressing both at the same time, [not one of them a split sec, before the other one] and are you holding them long enough?
Try a reboot, disconnect the batt. neg. terminal, wait a few min. reconnect and try programing again.
If it does not work there may be something wrong with the unit.
You do know you have the silent arm/disarm feature, [press button II first then button I]
94
</TD></TR></TABLE> are you sure you are pressing both at the same time, [not one of them a split sec, before the other one] and are you holding them long enough?Try a reboot, disconnect the batt. neg. terminal, wait a few min. reconnect and try programing again.
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> are you sure you are pressing both at the same time, [not one of them a split sec, before the other one] and are you holding them long enough?
94</TD></TR></TABLE>o trust me,i've tried everything.Yeah the only way i put the alarm on is silently.ESPECIALLY when there's other people around,lol
so do you think by buying a new siren it'll do the trick?
94</TD></TR></TABLE>o trust me,i've tried everything.Yeah the only way i put the alarm on is silently.ESPECIALLY when there's other people around,lolso do you think by buying a new siren it'll do the trick?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">I've never heard a gay voice module. Did it have a lisp and say "girlfriend" a lot? Must have been a factory defect.</TD></TR></TABLE>yep,it has a dual stage shock sensor.When a light shock happens it says "AS IFF!" and if someone tries to break in,it says "like OMG!get off my fender!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 »</TD></TR><TR><TD CLASS="quote">so do you think by buying a new siren it'll do the trick?</TD></TR></TABLE>It will not, the siren and alarm brain are the same unit along with dual stage shock sensor.
94
94
civhatch90
Audio / Security / Video
May 12, 2005 07:37 PM
