What kind of cam gear is this?
Old Jul 18, 2006 | 01:26 PM
BlackHXCoupe's Avatar
Default What kind of cam gear is this?
It says "Hayame" on it. Never heard of it. Is it a quality cam gear? Or is it junk?
edit: Anyone know if they're stock camshafts?
Modified by BlackHXCoupe at 11:44 AM 7/19/2006
Old Jul 18, 2006 | 03:12 PM
Silverhatch's Avatar
yes its hayame i would imagine they wold work because they have 6 bolts so they shouldent slip
Old Jul 18, 2006 | 03:41 PM
jp8900's Avatar
Default Re: (Silverhatch)
Definitely good on the 6 bolt part of the cam gear but those teeth look a little chewed up.... Bump for more answers on teeth wear and whether or not its going to affect the timing belt.
Old Jul 18, 2006 | 05:46 PM
Default Re: (jp8900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jp8900 &raquo;</TD></TR><TR><TD CLASS="quote">Bump for more answers on teeth wear and whether or not its going to affect the timing belt.</TD></TR></TABLE>
Old Jul 18, 2006 | 06:44 PM
Felt.2's Avatar
Default Re: (BlackHXCoupe)
yea 6 is straight
Old Jul 19, 2006 | 10:44 AM
Default Re: (Felt.2)
Old Jul 19, 2006 | 10:46 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: What kind of cam gear is this? (BlackHXCoupe)
I always thought Hayame was a ghetto Tanabe. :shrugs:
Can't tell if the cam is stock unless there are pics of the distributor-side end
Old Jul 19, 2006 | 10:56 AM
Default Re: What kind of cam gear is this? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I always thought Hayame was a ghetto Tanabe. :shrugs:
Can't tell if the cam is stock unless there are pics of the distributor-side end</TD></TR></TABLE>
I have no idea? Can anyone else chime in about this??
There were no markings whatsoever on the distributer side? The only markings on them were towards the front that were letters like "6" and "M" on one and "L" and "Y" on the other one.
Old Jul 19, 2006 | 11:48 AM
teknoracing's Avatar
Searched and found this.
http://www.spwusa.com/hayame/camgears.php
Doesnt give too much info on performance increase.
Old Jul 19, 2006 | 06:29 PM
Default Re: What kind of cam gear is this? (teknoracing)
Anyone else?
Old Jul 19, 2006 | 07:06 PM
JDM B16A's Avatar
I'm positive those are not stock.
Old Jul 19, 2006 | 08:41 PM
sinister6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jp8900 &raquo;</TD></TR><TR><TD CLASS="quote">Definitely good on the 6 bolt part of the cam gear but those teeth look a little chewed up.... Bump for more answers on teeth wear and whether or not its going to affect the timing belt.</TD></TR></TABLE>
In my personal experience, as long as the belt fit tight. you're fine..
my Toda been chewed up a bit from a loose teeth belt. the car still runs strong after rebuild and occationally rev up to 9500.
Old Jul 19, 2006 | 10:10 PM
rodrez.'s Avatar
My roomate used a set of Hayame's on his LS/VTEC build and they never slipped, however the teeth wore down rather quickly, and caused belt slip (OEM belt, CTR cams, OEM tolerances), he threw them away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">
Doesnt give too much info on performance increase. </TD></TR></TABLE>
Because every motor will be different.
Old Jul 20, 2006 | 11:17 AM
Default Re: What kind of cam gear is this? (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">I'm positive those are not stock.</TD></TR></TABLE>
The Camshafts?
Old Jul 20, 2006 | 11:20 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackHXCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
The Camshafts?</TD></TR></TABLE>
Pretty sure he meant the gears.
Try to get a pic like this:
Old Jul 20, 2006 | 11:44 AM
Dunno if this helps.
Old Jul 20, 2006 | 11:50 AM
cute little bastard
I'm gonna go with
I could be wrong though
Old Jul 20, 2006 | 11:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna go with
I could be wrong though</TD></TR></TABLE>
Looks about right? haha Thanks dude.
Old Jul 20, 2006 | 11:52 AM
Projekt_2nr's Avatar
if i was in the position that you are in i'd say to throw them away and purchase new cams and gears, we built a b18c with skunk2 cams and unorthadox gears and it beautiful, but to each his own.
Old Jul 20, 2006 | 11:54 AM
Default Re: What kind of cam gear is this? (Projekt_2nr)
look at the wear on the right gear compared to the left, thats a definit sign to buy new gears
Old Jul 20, 2006 | 12:16 PM
I'm not looking to rebuild any of this. I'm lookin to sell it all.
donny D
May 26, 2017 07:03 AM
Cuong-nutz
May 16, 2005 03:55 PM
adaml2nv
Dec 1, 2004 07:41 PM
pwrofdrm
Jul 24, 2004 09:23 PM
