running lean need help!!!
Old Jul 18, 2006 | 01:18 PM
yz125rider21's Avatar
Default running lean need help!!!
I am running lean I take it cause my spark plugs are white as can be at the moment and when I smog I am putting out high NOx...whats the best way to richen up the motor but I dont want to be spitting gas out the exhaust from not being burned...
Old Jul 18, 2006 | 05:45 PM
ttt
Old Jul 18, 2006 | 07:52 PM
new filter and new injectors...if it was just one the plugs would show diff colors...and fuel pressure is aroun45 so cant be that,,,,
Old Jul 19, 2006 | 02:35 AM
bump
Old Jul 19, 2006 | 03:48 AM
davens's Avatar
what ecu?
How old is the o2 sensor?
I wouldn't touch that no2 until you get this figured out.
Old Jul 19, 2006 | 02:33 PM
its pm6 or whatever everything pretty much stock on my d16a6 but header and CAI....and o2 is new. and I was wondering why my car seems to get so hot I check out the spark plugs and they all white as can be but ring is black so I take it runs rich at startup(warmup)...
Old Jul 19, 2006 | 04:04 PM
davens's Avatar
I would verify that you are, in fact, running lean with something like an EGT sensor or even wideband o2 sensor.
Just generally speaking...You could have a clogged fuel injector or fuel filter, bad MAP sensor, low fuel pressure, a leak in the exhaust system, a vacuum leak, a bad O2 sensor or a cracked PCV hose.
It's a hard problem to chase.
Old Jul 19, 2006 | 05:12 PM
about take it to a smog place that fixes issues and see what they say
Old Jul 19, 2006 | 06:18 PM
Crx Jimmy's Avatar
Default Re: running lean need help!!! (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">I am running lean I take it cause my spark plugs are white as can be at the moment and when I smog I am putting out high NOx...whats the best way to richen up the motor but I dont want to be spitting gas out the exhaust from not being burned...</TD></TR></TABLE>
dont go by spark plug reading unless you do a full throttle plug chop. if you take the plugs out after the car has idled even just a little the plugs will read the last condition they saw -lean at idle is normal there is no load on the engine, to read the plugs you have to have load on the engine like driving hard or up a hill and then just turn off at full throttle. then see what your plug looks like
Old Jul 19, 2006 | 07:47 PM
i see I thought they turn golden brown or something when its running good always???but I take your advice..I just retard timing 1 more degree and go smog it tomorrow...
Old Jul 19, 2006 | 09:42 PM
ok so I retarded the timing and the motor engauges into gear 100% smother...question is why do I have to retard it 2 degree beyond stock to get it to run smooth???
Old Jul 20, 2006 | 12:09 AM
any advice on why car is like this??? when I get money i be upgrading fuel rail and geting a fpr so I can have more controls over the fuel adjustment instead of just retarding the timing to keep it fmr leaning out...
Old Jul 20, 2006 | 12:58 AM
where is the tech in this forum anymore.............
Alex_S
Apr 29, 2013 05:03 AM
lmike6453
Nov 26, 2007 08:02 PM
fitbmx86
10
May 22, 2007 06:39 AM
AllMotorDA9
Oct 26, 2004 10:24 AM
SICKSOLSI
Jul 27, 2004 10:15 PM
