Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Come race Lime Rock with NASA NE!
Old Jul 18, 2006 | 12:47 PM
JoeLee's Avatar
Default Come race Lime Rock with NASA NE!
NASA Northeast will be at Lime Rock Park on August 4th and 5th (Fri-Sat is a weekend at LRP). We will be hosting a special race-only event shared with the VSCCA. Registration can be found at: https://www.nasaproracing.com/...d=317
We hope to see some Hondas out there!
Old Jul 18, 2006 | 04:41 PM
luder94-ChrisA's Avatar
Default Re: Come race Lime Rock with NASA NE! (JoeLee)
AH-Yeah!
I'll be there doing timing & scoring that weekend!
Old Jul 18, 2006 | 07:13 PM
speedracer33's Avatar
Default Re: Come race Lime Rock with NASA NE! (luder94si)
any suggestions on how to test your engine dbs without driving all the way to CT to be turned away for having a loud car?
Old Jul 18, 2006 | 07:15 PM
Lo-Buck EF's Avatar
Default Re: Come race Lime Rock with NASA NE! (speedracer33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer33 &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions on how to test your engine dbs without driving all the way to CT to be turned away for having a loud car?</TD></TR></TABLE>
good call. i'm not sure what the db will be since its a race weekend but im sure its under 100db.
Old Jul 19, 2006 | 03:57 AM
granracing's Avatar
Typically LRP's muffled days is 89 db and is measured from the inside of the track (hint, hint). There's a reason why most people have their exhaust tips pointing towards the outside of the track.
If you think that you may do other db limited events at tracks, it would be worth buying some type of resinator. I bought a supertrap extension, drilled a hole throught the sleeve and end of the exhaust pipe. It just slips on the pipe, a bolt is inserted to hold it on, and it does a pretty decent job of quieting the car.
Old Jul 19, 2006 | 09:12 AM
jfo's Avatar
jfo
I think radio shack has a cheap db meter. Open carefully, use once, repack and return.
Old Jul 19, 2006 | 12:04 PM
solo-x's Avatar
Default Re: (granracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">Typically LRP's muffled days is 89 db and is measured from the inside of the track (hint, hint). There's a reason why most people have their exhaust tips pointing towards the outside of the track.
If you think that you may do other db limited events at tracks, it would be worth buying some type of resinator. I bought a supertrap extension, drilled a hole throught the sleeve and end of the exhaust pipe. It just slips on the pipe, a bolt is inserted to hold it on, and it does a pretty decent job of quieting the car. </TD></TR></TABLE>
it's gonna be kinda hard to be so smug about beating sound when the locals shut the place down for good. (hint, hint). quiet your **** up if you think it's gonna be too loud.
Old Jul 19, 2006 | 12:39 PM
JoeLee's Avatar
The decibel limit will, unfortunately, be 89db.
There will be camping allowed at the track.
Old Jul 20, 2006 | 07:53 AM
philstireservice's Avatar
We'll be there too Joe......
Yes, Phils Tire Service will be at Lime Rock supporting NASA NE at the Aug 4th and 5th event.
Get your tire orders in early !!! July 27th is the cutoff date.................
Old Jul 20, 2006 | 01:31 PM
Zephyr-The Subaru Guy's Avatar
I will be there but only for Saturday.
Tyson
Jan 28, 2006 11:08 PM
Full-Race Motorsports
Mar 10, 2005 10:39 AM
GreenFlag
42
Feb 25, 2005 10:03 PM
CRX Lee
10
Jul 18, 2003 07:27 PM
