HELP!!! How bad is my ECU fried!!??!!
Old Jul 18, 2006 | 10:44 AM
blu3g's Avatar
Default HELP!!! How bad is my ECU fried!!??!!
hey guys.... my car is a 94 civic hatch dx... with a d16z6 swap in it. What I currently had in there was a p28 with a vafc1 hooked up to it. My car was broken into and they unplugged my ecu and ripped the vafc1 off the harness. I rewired everything back and had my brother send me an ecu that he bought off a guy from florida and im located in oklahoma. When i plugged the ecu in and i started my car up.... i smelled burning from my car.. after searching for it... it was coming from the ecu that i just plugged in. I opened up the ecu and there's a burnt mark on it.... we'll i guess the pix will best explain itself... but can anyone that have knowledge in ECU please tell me what is burnt, can it be fixed, or is it still usable.
Also i checked for trouble codes and its throwing out a 40.... I have no idea what a 40 is???? If anyone knows what a 40 is let me know.... but as of right now the car can still run with that ecu
thanks
Top View of ECU notice the burnt mark towards the front of the ecu
Closer shot to the burnt mark
something that cracked (anyone know what that is)
rear view of how it is burnt
closer rear view of how it is burnt
i dont think this pix matters but its just the rear cover
Modified by blu3g at 11:13 AM 7/18/2006
Modified by blu3g at 11:42 AM 7/18/2006
Old Jul 18, 2006 | 10:55 AM
NJcoupe's Avatar
Seems to be as if you swapped the IAT and IACV plugs, it will be fine for the most part, but your readings will be a little off.
Old Jul 18, 2006 | 05:52 PM
blu3g's Avatar
hey guys your input would greatly be appreciated
Old Jul 18, 2006 | 06:17 PM
commotion's Avatar
Default Re: (blu3g)
let me guess u didnt bolt it in = not grounded?
Old Jul 18, 2006 | 07:08 PM
Jim Truett's Avatar
Default Re: (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">let me guess u didnt bolt it in = not grounded?</TD></TR></TABLE>
The case is isolated so it doesn't matter.
There is either a short in the wiring for the EVAP purge solenoid, or the IAT sensor plug and the EVAP purge solenoid plugs are swapped.
Old Jul 18, 2006 | 10:28 PM
blu3g's Avatar
I thought it was my vtec selonoid and the vtec oil pressure switch.... will that mess it up? well guys if its like this... will it still be safe to use the ecu?
Old Jul 19, 2006 | 03:14 PM
blu3g's Avatar
ttt plz you guys that are ecu experts plz help me out?
Old Jul 19, 2006 | 03:17 PM
Relic1's Avatar
**edit**
you swapped the IAT and charcoal canister purge valve plugs
this blows up Q31 (as you did)
your IAT may be blown.
the ECU should be fine but the purge valve control will be gone. No CEL, the purgr valve is an emissions device. It runs fuel tank vapors into the intake manifold when you're cruising.
More than likely you messsed something up when you rewired things or it was always popped like this and you did something else to let out some smoke...
CEL 40 or CEL 4????
Modified by Relic1 at 6:28 PM 7/19/2006
Old Jul 19, 2006 | 05:33 PM
blu3g's Avatar
thanks for an expert opinion on it....
§95HATCH§
May 16, 2009 07:19 PM
blu3g
Jul 20, 2006 01:20 PM
_HANS
Jun 13, 2004 03:33 PM
