motor mount insert
Old Jul 18, 2006 | 12:26 AM
90efSI's Avatar
Default motor mount insert
well i got the energy suspension motor mount insert kit and i was wondering how do i install these??? i hear the rear one is the hardest??? what makes it so hard.
Old Jul 18, 2006 | 10:00 AM
90efSI's Avatar
....nobody knows ???
Old Jul 18, 2006 | 11:09 AM
kcjohnnyboy's Avatar
Default Re: (90efSI)
its a pita because you got to take the bracket off and intake manifold...
Old Jul 18, 2006 | 11:49 AM
thesmogman's Avatar
Default Re: (kcjohnnyboy)
No, It is the bolt that holds the mount to the cross member. You just need a long extension to get to it. Remove the bracket that holds the map sensor. Feed the extension through the heater slide switch then put the socket on the extension.
It is not hard just harder than the rest.
Old Jul 18, 2006 | 11:57 AM
ludesrv's Avatar
I just got mine, I'm gonna do this this weekend. I can remove my rear bracket with 1 arm tied behind my back and 1 eye shut. Infact, I might even take a picture of me doing that .
Old Jul 18, 2006 | 12:21 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (ludesrv)
get ur impact tools, take mounts off, put the inserts in, put mounts back in, = 30 min job.
Old Jul 18, 2006 | 03:30 PM
90efSI's Avatar
Default Re: (floss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">No, It is the bolt that holds the mount to the cross member. You just need a long extension to get to it. Remove the bracket that holds the map sensor. Feed the extension through the heater slide switch then put the socket on the extension.
It is not hard just harder than the rest.</TD></TR></TABLE>
pics would be great dude!!! lol i could care less about the one arm thing tho... just would like pics... maybe even a write up?!?!?
Old Jul 21, 2006 | 04:57 PM
90efSI's Avatar
alright well i still dont understand how to install these??? do i rip the old rubber out??? just slide the inserts in??? wouldnt they slide out??? i need help!!!
Old Jul 21, 2006 | 05:14 PM
Loserkidwac's Avatar
They are inserts you you put them on the stock rubber, they are cut to fit inside the openings in the mounts to stiffen them up, they even fix ripped/torn mounts, jst put one on each side and then some have those zip tie things put those in and tight then them or just push them in as far as they go and reinstall the mount...they really aren't that difficult, the hardest part is removing th mount from the car
Old Jul 21, 2006 | 07:18 PM
downest's Avatar
Default Re: (Loserkidwac)
Dont think it makes too much difference, but I like to put a little of that window-weld stuff in there with them. It's the stuff people use to make the ghetto poly inserts, polyurethane in a caulking gun. just put a little in there and squeeze the inserts in, it will hold them in there pretty well so they wont pull out when you don't line the mount up right installing a motor or something. Also I've heard these things squeak... never heard one squeak doing it this way.
Old Jul 22, 2006 | 12:30 AM
90efSI's Avatar
Window weld? could i find this at home depot????
Old Jul 22, 2006 | 07:57 AM
downest's Avatar
Home depot has their own brand. All that matters is that it's polyurethane window sealer (not silicon). Window weld is the 3M brand.
Old Jul 26, 2006 | 09:17 PM
90efSI's Avatar
expletive!!! dude there is no way that engine mount is coming out!!!!! now im probably gonna have to bring it to a shop b/c there is no ******* way!!!!!
Old Jul 26, 2006 | 11:35 PM
biggdogg's Avatar
u give up tooo easy
ConceptVBS
Honda Civic (2001 - 2005)
Apr 17, 2014 06:14 AM
mateo5046
Apr 14, 2008 01:04 PM
the.hamburglar
Jul 21, 2005 02:47 PM
O16581724 5 2 5
May 30, 2005 10:35 PM
jdub db8
Nov 26, 2004 09:30 PM
