Have to use distilled water for radiator?
Old Jul 17, 2006 | 09:36 PM
miksew's Avatar
Default Have to use distilled water for radiator?
Or is regular water fine?
Old Jul 17, 2006 | 09:37 PM
BlueIntegraBoy's Avatar
Default Re: Have to use distilled water for radiator? (miksew)
Regular is fine
Old Jul 17, 2006 | 09:52 PM
ddd4114's Avatar
well, ideally you should use distilled, but it won't matter that much. Just don't fill it with untreated lake water, and you'll be fine.
Old Jul 17, 2006 | 10:55 PM
Mt3c's Avatar
25 Year Member
Default Re: Have to use distilled water for radiator? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">i usually just take a gallon of coolant, pour the whole thing in, then fill the rest with a water hose till it spills out</TD></TR></TABLE>
so you don't bother getting a proper mix?
You should at least try to get 50% water. The water will transfer heat better, and the coolant will help with corrosion and lower freezing point.
NA_H22_Ej
Jun 17, 2006 10:24 PM
vynster
Jun 17, 2004 07:00 PM
onyx00
Jun 12, 2002 06:01 PM
onyx00
Oct 29, 2001 09:23 AM
94vteclude
May 18, 2001 01:58 PM
