** WHICH A/C BRACKET FOR B-SERIES INTO EK **
Old Jul 17, 2006 | 08:34 PM
IT'S ME DAVID's Avatar
NooB
Default ** WHICH A/C BRACKET FOR B-SERIES INTO EK **
I have a b16a2 into my ek.i have the civic type r bracket but tis not the right one.which a/c bracket do i need to make it work for my b16a2 into ek.
Also will need the part # if available.
Old Jul 17, 2006 | 08:49 PM
lshatch916's Avatar
Default Re: ** WHICH A/C BRACKET FOR B-SERIES INTO EK ** (IT'S ME DAVID)
i thinks a p7j or p54 will work
Old Jul 17, 2006 | 09:13 PM
NooB
Default Re: ** WHICH A/C BRACKET FOR B-SERIES INTO EK ** (lshatch916)
ok which one is it.what car is it off of.
Old Jul 17, 2006 | 09:18 PM
H9Omega's Avatar
the p54 is off of a del sol b16a3 and the p7j is from a crv B20
Old Jul 17, 2006 | 09:21 PM
NooB
Default Re: (H9Omega)
i heard they both may work.but can some one confirm which one will work though.
Old Jul 17, 2006 | 09:25 PM
Tuesdaynightfever's Avatar
You need the a/c compressor mount from a 94-97 del sol vtec or a crv...the stock compressor will work fine as long as you have the mount
Old Jul 17, 2006 | 09:36 PM
NooB
Default Re: (Tuesdaynightfever)
so both the crv and the del sol will work without modification.
Old Jul 17, 2006 | 09:40 PM
lshatch916's Avatar
Default Re: (IT'S ME DAVID)
the p7j will work for shizzle its on my boy ek with his motor now
Old Jul 17, 2006 | 09:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">so both the crv and the del sol will work without modification.</TD></TR></TABLE>
From what I read on the site so far both are confirmed to work by people that have them.
Old Jul 17, 2006 | 09:50 PM
NooB
Default Re: (lshatch916)
ok thanks for the info.any of you have part # for the crv bracket.
Old Jul 17, 2006 | 09:59 PM
94hatchling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for the info.any of you have part # for the crv bracket.</TD></TR></TABLE>
38930-P7J-000
Old Jul 17, 2006 | 10:02 PM
NooB
Default Re: (94hatchling)
perfect thanks.any body have a clue what it cost from the dealership.
Old Jul 17, 2006 | 10:04 PM
$65 from http://www.hondaautomotiveparts.com
Old Jul 17, 2006 | 10:05 PM
NooB
thanks so most likely from my local dealer its about $20 more then that site.
Old Jul 17, 2006 | 10:55 PM
97hb's Avatar
I used the p54 and everything bolted up perfectly.
Old Jul 18, 2006 | 11:15 AM
NooB
Default Re: (97hb)
im going right now to order the p7j crv bracket.
Old Jul 18, 2006 | 03:16 PM
NooB
i just ordered the crv bracket.$94 with taxes..hope it works.
Old Jul 18, 2006 | 07:55 PM
93Civac's Avatar
IT will, I used the crv in my 96 hatch with 2000 b16a2 swap.
EJ8chu
Feb 9, 2007 05:24 AM
SierraSonic
Aug 2, 2006 05:41 PM
t_dot_SiR
Jul 1, 2006 09:23 AM
technica
Jul 25, 2005 04:45 PM
forcefedish
Jun 1, 2005 08:47 AM
