Best resource for SWAP
Old Jul 17, 2006 | 06:32 PM
crxpwr1's Avatar
Default Best resource for SWAP
whats up...well im doing a b16 swap into a rex and Ive found about 8 resource sites......I have mostly every thing for the swap got my mounts, shift linkage, resistor box, throttle cable, but still need axles and once the engine gets here ima send my wire off to rywire and im also going to get some radiator hoses.
1.) Do you have to bend the back cross-member to fit the mount?
2.) Water pump, timing belt, distributer cap and rotor, spark plugs and wires, valve cover and spark plug o-ring gaskets, clutch....how much would it cost for all this to be replaced?
3.) and whats the best site to follow...I mean I have a bunch of sites just wondering what everyone else used and how it worked?
Old Jul 17, 2006 | 06:37 PM
Autoworks's Avatar
Default Re: Best resource for SWAP (crxpwr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">
3.) and whats the best site to follow...I mean I have a bunch of sites just wondering what everyone else used and how it worked?</TD></TR></TABLE>
1. No
2. probably $60
3. look in the FAQ's there are several detailed write ups
Old Jul 17, 2006 | 06:40 PM
crxpwr1's Avatar
Default Re: Best resource for SWAP (Autoworks)
ive looked in the faqs and seen the sites there really good just wondering if any one else used it or another one that was better. I have about 3 sites added to my favorites
Old Jul 17, 2006 | 06:55 PM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
2. probably $60
um.. its going to be more than $60 lmao. the water pump alone is going to be like $30-$50 from the places ive checked. timing belt depending on how seriouse you wanna go, $30-160 (remember, if the timing belt snaps your engine is fucked, so you wanna leave your motor in the hands of a cheap oem replacement?), plugs and wires maybe $40 total if going oem, an entire oem gasket set will run for around $100, the clutch itself i dont know, most places ive seen sell it in kits not single
so ya please tell me where you are getting all that for $60? I'm planning on spending $250+ for most of that
Old Jul 17, 2006 | 09:17 PM
crxpwr1's Avatar
Default Re: Best resource for SWAP (Bjorn20)
what faq did every one use for your swap
Old Jul 17, 2006 | 10:11 PM
crxpwr1's Avatar
bump
FlewByU352
Oct 9, 2009 04:01 AM
louie3252
Mar 10, 2006 12:05 AM
IntegraMastaz
Apr 21, 2005 09:42 AM
BLK99VTECR
Mar 1, 2004 11:10 AM
plusONE jboy
Nov 19, 2003 09:37 PM
