what should i do ls or d-series
Old Jul 17, 2006 | 06:28 PM
beatthisspeed69's Avatar
Default what should i do ls or d-series
well im kind of debating on wat to do im on a budget and cant think of wat to do....im either thinking of do a turbo d becuase i can get a turbo for a d-series realy realy cheap from my friend or should i just get a ls and put it in cuz i can get one cheap at the junkyard cuz they have millions of them but i would also have to by motor mounts and shift linkage so that will cost extra money...i kinda want the one that will have more power im kinda leaning towards the turbo d-series but just wwanted some opinions on wat i should do......oh yea im just gonna be using my car for a daily and for the races on the weekends
Old Jul 17, 2006 | 06:34 PM
crxpwr1's Avatar
Default Re: what should i do ls or d-series (beatthisspeed69)
I would go with ls then turbo it later on...later on it will be way more powerful then the d series could be
Old Jul 17, 2006 | 06:37 PM
Tippyman's Avatar
D series parts are cheap as **** though. I'd turbo the D. That way wen u blow it up it'll be nothing to rebuild it.
Old Jul 17, 2006 | 06:43 PM
crxpwr1's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">D series parts are cheap as **** though. I'd turbo the D. That way wen u blow it up it'll be nothing to rebuild it.</TD></TR></TABLE>
good point
Old Jul 17, 2006 | 06:45 PM
thats wat im saying cuz im only 15 with no job and if someting goes wrong with the ls i wont be able to afford it...it will be a long *** time b4 i can even get the ls in the car....how much hp would i expect out of a turbo a6
Old Jul 17, 2006 | 06:54 PM
Loserkidwac's Avatar
Default Re: (beatthisspeed69)
200-220 is about the limit on a stock D before th ringlands snap, I don't know I personally would do the LS swap since it will be more reliable for DD than a turbo car, also in the end you can push a stock LS turbo to 300+ hp
I had a turbo a6 and I swapped to a LS and am boosting it shortly, I say skip the D and go to B
Old Jul 17, 2006 | 07:05 PM
mr_nemesis2003's Avatar
Someone save a D. I'm sticking with a d for now, since i am a college student and money is pretty hard to come by. Plus, like the other guy said, it is cheaper. But... there is a but, i am planning on getting a b16 or b18 and supercharging it so it can be a fun track car in the future. Also, if you mess up something on the D, it won't be as much.
Old Jul 17, 2006 | 07:11 PM
EF9-CIVIC's Avatar
Default Re: (mr_nemesis2003)
ls and boost it.
Old Jul 17, 2006 | 07:18 PM
sic944t's Avatar
Default Re: (EF9-CIVIC)
its a simple money issue
d series cheap
b series better
the pros and cons are well written on each motor but i would say in your shoes just go d series and after some time and maybe some engines you can allways go to a b series but if you are learning and starting you might aswell blow up a cheap engine or two ...
Old Jul 17, 2006 | 07:22 PM
Default Re: (sic944t)
IF he decision is between Boosted D or a B swap then it is going to cost about the same...for a daily drive N/A is better than Boot, well more reliable
Old Jul 17, 2006 | 07:48 PM
i think ima boost the d then later on down the road wen i have a job and more experience ima get a b series...thnx for the opinions everybody realy appreciate it
Old Jul 17, 2006 | 10:12 PM
d16vtecx's Avatar
good choice
turbo D &gt; LS
Old Jul 17, 2006 | 10:31 PM
psycho.chicken's Avatar
Default Re: (d16vtecx)
an LS swap is not cheap... unless your good friends with the local wrecking yard...
Old Jul 18, 2006 | 04:15 AM
StorminMatt's Avatar
Default Re: (psycho.chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psycho.chicken &raquo;</TD></TR><TR><TD CLASS="quote">an LS swap is not cheap... unless your good friends with the local wrecking yard... </TD></TR></TABLE>
Not true. Around here, you can get them all day long at the local pick-and-pull. The cost? Nothing more than a D-series motor from the pick-and-pull. A motor (or any other given part) costs the same, regardless of what it come out of. So if you blow up an LS, it's not like replacing oneis going to set you back more than replacing a D-series (especially a D16Z6, which is actually harder to come by around here and likely more expensive). True, you have to buy a mount kit. But you can get these downright cheap these days. So why settle for a D if you really don't have to?
Old Jul 18, 2006 | 05:16 AM
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Not true. Around here, you can get them all day long at the local pick-and-pull. The cost? Nothing more than a D-series motor from the pick-and-pull. A motor (or any other given part) costs the same, regardless of what it come out of. So if you blow up an LS, it's not like replacing oneis going to set you back more than replacing a D-series (especially a D16Z6, which is actually harder to come by around here and likely more expensive). True, you have to buy a mount kit. But you can get these downright cheap these days. So why settle for a D if you really don't have to?</TD></TR></TABLE>
Thats exactly how it is around hee i can get any 4 banger for about $100 and trannies are $60....and There at atleast 2-3 there every month
I've done both D series turbo and a now a B swap and to do either correctly and finding good deals, they will cost the same in the end the B is a better upgrade...but the OP has made up his mind for a boosted car which is cool but not for a DD
Old Jul 18, 2006 | 12:25 PM
91SiZ6's Avatar
The one thing I truly love about HT. Maybe 3% of the people here actually understand the potential of a D-Series motor.
Old Jul 18, 2006 | 12:28 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 &raquo;</TD></TR><TR><TD CLASS="quote">
thats wat im saying cuz im only 15 with no job and if someting goes wrong with the ls i wont be able to afford it...it will be a long *** time b4 i can even get the ls in the car....how much hp would i expect out of a turbo a6</TD></TR></TABLE>
Then you shouldn't play cars
Get a job get all your bills etc settled start some investments then play cars.
Do you really think it would be honestly cheaper to fix a broken stock LS comparing that to a boosted D?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">The one thing I truly love about HT. Maybe 3% of the people here actually understand the potential of a D-Series motor.</TD></TR></TABLE> More do less care
Old Jul 18, 2006 | 01:35 PM
1990si's Avatar
im going to boost a zc once my mini me is done....
nitewolf
Oct 7, 2008 06:04 AM
Dc295kid
Oct 1, 2008 02:11 PM
desiromeo812
Sep 10, 2008 04:42 AM
drowzysleeper
Jun 1, 2005 01:28 PM
bboylito
Oct 27, 2004 05:36 PM
