im putting this system together; any advice?
Old Jul 17, 2006 | 10:59 AM
hondaZvic's Avatar
Default im putting this system together; any advice?
i have an Alpine 9856 CDA cd player.
and an Infinity Reference 1032w
i was thinking of purchasing an Alpine MRP-M450 amp.. is this a good choice?
im not trying to blow any doors off or anything, i just want an amp that will not overpower or underpower my speaker to much.
i would like to keep my products limited to those 2, alpine or infity.
tia.
Old Jul 17, 2006 | 11:05 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: im putting this system together; any advice? (hondaZvic)
you will be fine.
Old Jul 17, 2006 | 11:13 AM
RotiEatter's Avatar
Ditto
I know nothing about stereos, but I have both an Alpine CD Player and Amp. I like Alpine. You should be fine.
Old Jul 17, 2006 | 01:14 PM
darkspector's Avatar
It'll sound good.
Old Jul 17, 2006 | 05:35 PM
hondaZvic's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">I know nothing about stereos, but I have both an Alpine CD Player and Amp. I like Alpine. You should be fine. </TD></TR></TABLE>
gosh your so much help. ahhahahahhaha
cool. thanks guys.
Old Aug 14, 2006 | 01:11 PM
hondaZvic's Avatar
Default Re: (hondaZvic)
bumping this up so u guys can see....
i installed those products from above, and im very pleased with them..
however it did take me alot longer than expected, partly because this is only the 2nd system i've installed. and because im a fan of the gutted cars... and i couldnt really figure out how to mount everything... but i finished it...
what yall think?
for the amp, i cut 4 small pieces of wood and mounted them to the floor, spacing it up a little bit so it can get some air underneath it.. that and the floor where i mounted it had those humps in it too..
for the box, i drilled a small hole in the bottom of it, and used a 12mm bolt to bolt it to the spare tire bolt hole. then i put some small peices of metal on the rear of it, and screwed it down to the floor...
more of a function over fashion thing...
Old Aug 14, 2006 | 02:36 PM
fcm's Avatar
fcm
Old Fart
Although the Alpine amp would work, you have a DVC 250W "RMS" sub, but the amp only puts out 220W RMS into 4 ohms or 400W RMS into 2 ohms, a little under-powered or a lot overpowered.
What is the impedance of the VCs, it was available in DVC 2 ohm or DVC 8 ohm, need to know what the impedance is to recommend an amp. 94
Old Aug 14, 2006 | 02:44 PM
02 accord's Avatar
Default Re: im putting this system together; any advice? (fcm)
Recommend an amp? I think it's a little late for that. He already got the alpine (as can be seen from the pics).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">a lot overpowered</TD></TR></TABLE>
Just because the amp puts out 400 wrms and the sub needs 250, doesn't mean that the amp has to be turned up all the way to put out that 400. Once set up right, I'd call it "a lot of headroom," not " a lot overpowered."
Old Aug 14, 2006 | 05:06 PM
hondaZvic's Avatar
lol....
yeah its a little late for any advice guys.. but oh well.. i dont think my speaker is gonna blow with this amp... it sounds good.
Modified by hondaZvic at 11:54 PM 2/12/2007
Old Feb 12, 2007 | 10:54 PM
hondaZvic's Avatar
hey guys, im bringing this one back from the dead ok...
i've come across someone that wants my Infinity 10.. soo im thinking of getting a 12.
my question is what would be a good 12 to put with this amp?
tia
Old Feb 13, 2007 | 12:17 PM
hondaZvic's Avatar
some 12's i've been looking at are the Alpine SWR-1242D or a Kicker one, but the kickers seem like they need more power than my amp has.. but im not really sure..
liquid_imagination
Audio / Security / Video
Oct 4, 2008 07:41 AM
Jdmglenn
Oct 24, 2006 11:18 AM
bisket
Nov 13, 2003 10:41 PM
