Does a coolant leak cause a veichle to run hot???
Hi, i have a very small leak in a coolant hose.. It pisses out when it gets to around 195 deg.. then i can smell it in the car and it slowly starts to rise till it gets to about 205-210ish..
Could this leak be allowing air to get into the system causing it to run hotter then normal? I plan to fix the leak and see if i notice any differences.. But im just curious.
Thanks.
Thanks.
yes... fix the leak... problem should go away. coolant system needs to be pressurized in order to function correctly. when there's a leak/hole... it can't maintain the pressure and therefore can't maintain the temps.
Modified by M.A.R.C. at 9:52 PM 7/17/2006
ah it sprays out.. Its not quite that much, but its enough to make my tranny all wet, and to smell it inside the car, and i notice that it runs OK as far as temp wise (it was 40 deg celceus today) and then i can start to smell the coolant.. its still at 195deg when this happens. Then once i begin to smell.. It slowly rises very slowly, i cant believe i never noticed this coolant leak before! Maybe because the majority goes behind the backside of the tranny and its hard to see. I will fix tommorow.. Just got home from a nightshift very tired.
i had a leak on the lower hose..it wasnt fully on so it drips out
i never saw it but can smell the ****..
it drives,holds temps fine
but when i used a/c and hit a big dip/bump my temps skyrockets!
then i looked under the car one day when its warming up and cought it
now it works flawlessly
yeah i put a small hole in my bypass hose last week. car drove fine for like 30 miles on the highway. the minute i stopped at the gas station and let the car sit for a minute to let the turbo cool down... i heard the coolant spray everywhere. i poured some more coolant in... drove it home fine lol.
