Oil pump vs money...
Old Jul 17, 2006 | 08:55 AM
HiProfile's Avatar
Default Oil pump vs money...
Here's the deal. I have a d16z6 running great besides low oil pressure that I want to fix, but will replace in a few months. I also have a d16z6 w/hole in the block (obliterated rod) I got for free. The motor runs ~10psi lower oil than it should, and when goes down to 20psi, it imediately drops to just above zero. I would guess its the oil pump (bypass spring), but it could be a rod issue too.
I was wondering if the oil pump (off the dead motor) would be alright to reuse for a short-term fix. I don't want to spend $80+ on a pump that I'm not sure will fix it on a block I won't be using for much longer. This isn't cali where there's d16's everywhere - here salvage yards want $200+ for a shortblock, and private sellers aren't that easy to find.
Old Jul 17, 2006 | 09:44 AM
Flashmn's Avatar
Default Re: Oil pump vs money... (HiProfile)
I dont think I'd want to skimp 80 bucks for an oilpump when the resulting damage or low oil pressure will be in the thousands.
Old Jul 17, 2006 | 03:59 PM
NJIN BUILDR's Avatar
Honda oil pumps are either good or broken.It is possible to have pressure relief issues but they are pretty rare.It sounds like you have a bearing issue.I don't believe a pump will solve your problem.
Old Jul 17, 2006 | 04:59 PM
HiProfile's Avatar
Default Re: Oil pump vs money... (NJIN BUILDR)
Thats what I was thinking. Worst case scenerio, I'd have a bearing spin or freeze, giving me a paperweight w/ or w/o a hole in the side & a head that needs the 150k+ valves replaced, or taken from one of the 2 spare vtec heads I have.
I think I'll just try to get the block I'm looking at, get the other civic moving, then build this block. As much as I hate to run things till they break, I hate being stranded while waiting for AAA even more.
Badassbigblock
Feb 17, 2018 01:19 PM
jarven093
11
Apr 30, 2007 07:00 PM
A-busive
13
Jul 22, 2006 05:07 PM
O16581724 5 2 5
Aug 21, 2005 10:36 PM
sk8rmike
Oct 8, 2003 08:41 PM
