Grounding - what happens if you don't ground?
Old Jul 17, 2006 | 08:24 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Grounding - what happens if you don't ground?
In general, is grounding the wire all that important? I understand the + and the -, but not grounding.
Old Jul 17, 2006 | 08:49 AM
Spicoli v 3.0's Avatar
Default Re: Grounding - what happens if you don't ground? (GoLowDrew)
- is the ground wire, and yes it matters alot. It completes a "circuit" if you have shitty ground on amps, it tends to lead to
A) static in speakers
b) Amp not workin
C) i'm sure there a third nasty one i'm just forgetting
Old Jul 17, 2006 | 11:24 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Grounding - what happens if you don't ground? (Spicoli v 3.0)
The third is friying your gear, I see people that have have mitsubishi galantes or what ever the are called. Come to me that there aftermarket headunits don't work anymore. They don't proplery ground the unit because the car side does not have a ground in the car radio harness and they just plug in the antenna for ground,
Old Jul 17, 2006 | 01:59 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I see people that have have mitsubishi galantes or what ever the are called. Come to me that there aftermarket headunits don't work anymore. They don't proplery ground the unit because the car side does not have a ground in the car radio harness and they just plug in the antenna for ground</TD></TR></TABLE>
Ahhh yes... One of my very first installs was in one of these gems... The Metra/Scosche Mitsu harnesses have a ground in them, so I just hooked it up, and never thought that there wouldn't be a ground in the car's harness... Wracked my brain for about an hour trying to figure out why the deck would dim and shut off when the volume was up... LOL... Good times...
So, to stop hijacking your thread, yes, grounding is important...
Old Jul 17, 2006 | 11:05 PM
suspendedHatch's Avatar
Default Re: (B18C_EJ8)
If you don't ground, you don't have power. You dont have ****. Plain and simple. Take the ground off your car battery and see how that works out for you.
RGoose18
Audio / Security / Video
10
Aug 21, 2009 08:29 AM
3ni_stylez
Jul 13, 2006 08:41 AM
B18C1 '96 Coupe
21
Oct 21, 2005 03:59 PM
Kavehman
Oct 30, 2004 05:44 PM
MooreBoost
Mar 7, 2003 02:45 PM
