90 crx si : rpm tach not working right???
Old Jul 17, 2006 | 06:57 AM
onefastasscivic's Avatar
Default 90 crx si : rpm tach not working right???
i have a 90 crx si and friday my factory rpm tach started acting weird. i doesnt work at idle and it moves really fast when accelerating....but it doesnt work until atleast 3000 plus rpms.
any suggestions?
Old Jul 17, 2006 | 07:13 AM
ludesrv's Avatar
Check the wiring for the tach at the dizzy. It could of failed. Also, replace the cluster with a known working one, another easy way to figuring out if it's your cluster or your wiring/dizzy that's messing up. Changing a cluster takes no more then 20-30 minutes.
Old Jul 17, 2006 | 07:24 AM
Smokinsax's Avatar
The Boot
also check the speedo cable that connects to the back of the cluster and where it inserts into the tranny.
Ive had my speedo cable break inside the tranny and it would catch everyonce in a while and jump around.
Old Jul 17, 2006 | 07:26 AM
ludesrv's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">also check the speedo cable that connects to the back of the cluster and where it inserts into the tranny.
Ive had my speedo cable break inside the tranny and it would catch everyonce in a while and jump around.</TD></TR></TABLE>
RPM tach and speedo are 2 different things.
Old Jul 17, 2006 | 07:35 AM
Default Re: (ludesrv)
i was also told to check the alternator?? is that correct?
Old Jul 17, 2006 | 07:50 AM
Loserkidwac's Avatar
Default Re: (onefastasscivic)
Open up the dizzy and make sure all the wires on the ignitor are tight, I had one loose ona new dizzy and slowly worked its way looser and started acting up...alt may be responsible but i believe you would have other symptoms with electronics...
My money is one loose wire or ignitor going bad
Old Jul 17, 2006 | 07:56 AM
Default Re: (Loserkidwac)
ILL CHECK WHEN I GET OFF OF WORK AND ILL LET YALL KNOW. THANKS EVERYONE
Old Jul 17, 2006 | 09:24 AM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
RPM tach and speedo are 2 different things.</TD></TR></TABLE>
on me. i dont know why I was thinking the speedo. weird
Clash0901
Dec 10, 2009 05:09 PM
ryan_crx
Jun 4, 2008 09:23 PM
civic889802
Jan 16, 2006 11:46 AM
crxtreme27
Jan 19, 2005 05:48 PM
Quick 200k Mile Motor
Jan 31, 2002 10:04 PM
