B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!!
Old Jul 17, 2006 | 06:24 AM
DetainedCivic's Avatar
Default B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!!
Ok I got the motor in the car over the weekend and it is all wired up with the help of some soldering, heat shrink tubing, and electrical tape. I have two parts to the motor left to hook up the AC Compressor which I now know I can use the dseries compressor with a del sol or crv ac bracket. Now comes the power steering. What do I need for the easiest solution. The motor is a jdm b16 gen2 obd1 motor. I have read that a 92-93 ps pump and bracket will bolt up and I can use the high pressure ps line already on the car. Is there another way. The b16 ps pump and bracket came with the b16 swap already attached with the lines cut. Can I use a different high pressure line instead and keep the ps pump and bracket that came with the motor???? Or can I use my ps pump that came off of my d16 with a different bracket?
Old Jul 17, 2006 | 11:31 AM
Default Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (DetainedCivic)
bump
Old Jul 17, 2006 | 11:35 AM
philosofy1's Avatar
i did the same swap. just use the same line, maybe from a salvage yard. as for the pump, it looked the same as the d-series, so maybe that'll work. the line bolts right to it, not sure about the bracket, don't have the motor anymore.
Old Jul 17, 2006 | 12:42 PM
Default Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (philosofy1)
Use the same line, which line, the line that will fit the b16 pump???
Old Jul 18, 2006 | 08:09 AM
I figured someone on this forum knew what they were talking about
Old Jul 18, 2006 | 08:35 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DetainedCivic &raquo;</TD></TR><TR><TD CLASS="quote">Use the same line, which line, the line that will fit the b16 pump???</TD></TR></TABLE>
the pump line from the b16 and the civic are the same.
Old Jul 18, 2006 | 09:36 AM
deckster333's Avatar
you can use the line from any 92-95 civic, but you MUST use a b16 (p30) ps pump and brackets
Old Jul 18, 2006 | 09:37 AM
philosofy1's Avatar
Default Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (deckster333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 &raquo;</TD></TR><TR><TD CLASS="quote">you can use the line from any 92-95 civic, but you MUST use a b16 (p30) ps pump and brackets</TD></TR></TABLE>
i was wondering the same. good to know since the b16 del sols are P30.
Old Jul 18, 2006 | 10:09 AM
Cool I will try the 92-95 ps line here soon. I have a friend with one laying around so I will take the b16 pump over to his house and see if it bolts up. I will let you know.
Old Jul 19, 2006 | 07:07 PM
Here is what I learned. I used the d16 ps pump and mounted it to the b16 block. HAd to use a longer bolt at the top. I also used the b16 pulley on the d16 pump. Tightened my belt and it looked good.
RicerBoi16
Apr 22, 2019 06:03 PM
XhaloZ
20
Mar 30, 2014 09:56 AM
Makdaddynuge
Aug 4, 2008 04:43 AM
DetainedCivic
Jul 20, 2006 11:51 AM
93civiconair
Mar 17, 2005 08:12 PM
