car wont start
Old Jul 17, 2006 | 01:47 AM
crxkid24's Avatar
Default car wont start
its getting spark and fuel. changed out the fuel filter....nothing. changed spark plugs, tried a different coil, compression check, injectors are good, fuses are good, no check lights, computer turns on, timing is on....car still wont start...what could it be?
Old Jul 17, 2006 | 02:53 AM
silverkorn's Avatar
Default Re: car wont start (crxkid24)
check your timing, if fuel and spark are good that only leaves timing
Old Jul 17, 2006 | 07:59 AM
Loach73's Avatar
Default Re: car wont start (silverkorn)
Try checking connections to the battery this happened to me once the ground wasn’t tight. Also check your battery with a battery just in case.
Old Jul 17, 2006 | 08:34 AM
crxkid24's Avatar
timing is good. battery is good. still nothing.
Old Jul 17, 2006 | 05:08 PM
crxkid24's Avatar
okay i put a pr4 computer in the car and it will start but i have to feather the gas to keep it running...as soon as i stop the car shuts off.
Old Jul 18, 2006 | 10:34 AM
crxkid24's Avatar
i figured it out....broken wire on the map sensor plug...it runs again...thanks everyone.
jonnybadboi9
Jul 15, 2009 09:39 PM
Jcon8
Mar 31, 2009 05:55 AM
junya16
Mar 1, 2003 05:41 PM
johnjohn410
Dec 17, 2002 10:21 PM
Timmayeg
17
Apr 29, 2002 07:34 PM
