ls/vtec parts..........
Just have a quick question. I want to know if anyone knows where I can find the following parts for my ls/vtec setup. Is there a wepage that sells this stuff brand new or used? I have everthing else but these parts. Any help appreciated
· '94-'01 Integra GS-R knock sensor (also Type R, del Sol DOHC VTEC and Civic Si)
· -4 steel braided hose with female ends, 22 inches in length
· 1/8-inch NPT female to 1/8-inch NPT female to 1/8-inch BSPT male on run pipe tee
· 1/8-inch NPT male to -4 male straight adaptor
· 3/8-inch NPT male to -4 male straight adaptor
· 1/8-inch internal pipe plug
· 1/8-inch NPT pipe tap
· 3/8-inch NPT pipe tap
· 14mm drill bit
· 10.9mm drill bit
· 12mmx1.25mm tap
· 14mm drill bit
· 10.9mm drill bit
· 12mmx1.25mm tap
