AC piece falls off
Old Jul 16, 2006 | 10:12 PM
Riced-EL's Avatar
Default AC piece falls off
I hit a pothole, and a weird noise appears...i get out, and the piece of the AC mounted to the motor and belt fell off....does any1 kno what this piece is called? this way i wont look dumb at honda and i'll kno wat bolts i need....
Old Jul 16, 2006 | 10:41 PM
Archidictus's Avatar
Unceasing Measure
Default Re: AC piece falls off (Riced-EL)
Probably a tensioning rod or pulley. Can you take a picture?
Old Jul 17, 2006 | 12:21 AM
axtran's Avatar
mounted to the motor and belt... he could have lost his whole compressor, lol
Old Jul 17, 2006 | 07:28 PM
Riced-EL's Avatar
its the piece mounted to the motor, w/a belt attached to it...
Old Jul 17, 2006 | 07:53 PM
Frozen E's Avatar
H-T White Ops
Clarify. Is it like a quart size paint can? If so, that's your compressor. I don't know how the hell that would have fallen off. More than likely it's the tensioner. Get a new one if yours is missing. They're not expensive.
Old Jul 17, 2006 | 10:37 PM
Riced-EL's Avatar
I am like 90% sure its the compressor...well its most likely b/c i paid **** money for a **** shop to do a swap....
Old Jul 17, 2006 | 10:41 PM
Frozen E's Avatar
H-T White Ops
pics??? i needa see this.
does it have 2 pipes coming out of it and a couple of wires?
Old Jul 17, 2006 | 11:07 PM
drumminforev's Avatar
Default Re: (IslandSi)
If your compressor fell off...walk bak to that shop and smile politely, then kick each one of them in their *****.
It wouldnt fall off onto the ground either, unless both the lines snapped, and you would see that, And you would have oily residue all over under your hood from ac oil blastin everywhere
Old Jul 17, 2006 | 11:13 PM
Frozen E's Avatar
H-T White Ops
Default Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">If your compressor fell off...walk bak to that shop and smile politely, then kick each one of them in their *****.
It wouldnt fall off onto the ground either, unless both the lines snapped, and you would see that, And you would have oily residue all over under your hood from ac oil blastin everywhere</TD></TR></TABLE>
Which is exactly why I want pics. I think the compressor's held in with 3 long *** bolts if I remember correctly.
I'm thinking it's his tensioner. Makes a shitload more sense than the compressor.
A lot of hardware needs to be missing in order for the compressor to just fall off.
Old Jul 19, 2006 | 08:20 PM
Riced-EL's Avatar
kkk...i shall take pix tmw nite...
Old Jul 19, 2006 | 08:25 PM
JDM_d15b_eg8's Avatar
Default Re: (Riced-EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL &raquo;</TD></TR><TR><TD CLASS="quote">its the piece mounted to the motor, w/a belt attached to it...</TD></TR></TABLE>
alright well there are two things i'm thinking of.
1) A/C compressor which has a belt that attaches to a pully which is BOLTED ON to the motor
2)power steering pump which also runs off a belt and pulley.
i'm thinking it was your AC pulley that fell off, but if it was then i'm thinking the belt would have flung off too. Is this mystery object real low in the engine bay, or is it higher up in the engine bay right behind the drive side light?
if its low then its AC, if its high then its power steering but again as pointed out earlier, if one of those major components fell off your gonna get a bunch of fluid from both, and probably crap all over your engine bay area. not to mention those are both secured pretty well, you must have really clocked that bump in the road to knock those suckers loose and make them fall off.....
Old Jul 20, 2006 | 06:54 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL &raquo;</TD></TR><TR><TD CLASS="quote">kkk...i shall take pix tmw nite...</TD></TR></TABLE>
where are the pictures? damn you!!! i wanna see how the compressor fell off.
Old Jul 22, 2006 | 05:22 PM
Frozen E's Avatar
H-T White Ops
You suck at taking/posting pics. Just wanted to let you know that.
chieftaco
10
Oct 11, 2009 03:38 PM
SuM Honda
Oct 6, 2008 08:40 PM
markysparky
21
Oct 30, 2005 08:03 PM
kb7709
May 16, 2005 05:38 AM
kmar111
Jun 20, 2004 05:25 PM
