which bolt do i remove to fill my tranny?
Old Jul 16, 2006 | 07:24 PM
nabin's Avatar
Default which bolt do i remove to fill my tranny?
im driving a b16a2 civic. drained the tranny, and now i cant find out where to fill it. i can fill from that spout on top, but i dont know how much to put in.....help help different spot?
Old Jul 16, 2006 | 07:29 PM
G2 Speed's Avatar
Default Re: which bolt do i remove to fill my tranny? (nabinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabinger &raquo;</TD></TR><TR><TD CLASS="quote">im driving a b16a2 civic. drained the tranny, and now i cant find out where to fill it. i can fill from that spout on top, but i dont know how much to put in.....help help different spot? </TD></TR></TABLE>
I would really suggest searching for this
either should be the same ****
https://honda-tech.com/zerothread?id=1687986
Old Jul 16, 2006 | 07:32 PM
Crx Jimmy's Avatar
fill it through the fill plug right above the axle, you fill it till it leaks out
Old Jul 16, 2006 | 07:42 PM
nabin's Avatar
thanks
Old Jul 16, 2006 | 09:07 PM
BlueIntegraBoy's Avatar
Yes, it will be easier from the bolt near the axle, but you can fill from the top. You'll need 2.1 quarts and it will take longer.
Old Jul 16, 2006 | 09:54 PM
Frozen E's Avatar
H-T White Ops
Take out the VSS (vehicle speed sensor) and fill through there
Old Jul 16, 2006 | 10:05 PM
SOHC4life 96's Avatar
Default Re: (IslandSi)
You fill it from the hole that you drained it from. And as stated before, you fill it till fluid starts to spill out.
Old Jul 16, 2006 | 10:08 PM
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">You fill it from the hole that you drained it from. And as stated before, you fill it till fluid starts to spill out.</TD></TR></TABLE>
There are two holes. A lower one (the one you drain) and a higher one (the one you fill til it overflows).
Old Jul 16, 2006 | 11:36 PM
hatchi's Avatar
either from vss or the bolt to the left of the axle
Old Jul 17, 2006 | 06:37 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">You fill it from the hole that you drained it from.</TD></TR></TABLE>
if this is what you do, you must burn up transmissions a lot.
Old Jul 17, 2006 | 07:18 AM
slowSOHCvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">if this is what you do, you must burn up transmissions a lot.</TD></TR></TABLE>
haha, yeah that guy must only get about an ounce of oil back into his tranny, there are two bolts, drain and fill bolt, use the search there is a sticky on how to change your MTF
Make sure to get the crush washers from honda or an autoparts store, don't want to have a leaky tran cuz of a 10 cent part
your b series tran holds right around 2 quarts, please search next time
https://honda-tech.com/zerothread?id=851521
edit: https://honda-tech.com/zerothread/1687986 heres a good article too, hope that helps!
Modified by slowSOHCvtec at 8:29 AM 7/17/2006
S1NFUL RL1 619
Mar 18, 2008 04:36 PM
pocketviper
Jun 3, 2007 05:36 PM
EK9 BEEZLER
May 4, 2005 11:03 AM
sLoWrAcEr
Apr 19, 2005 05:05 PM
vmm
Jul 6, 2004 03:06 PM
