Made a dumb ass mistake, now need help
Last night I was helping a friend swap a b16 into his 91 hatch. Got it all in and ready to go. Cranked a bunch of time and nothing. Checked for spark and it was good, right firing order. Pulled the plugs and no gas. Checked the fuel filter and gas was there. There was something on the plugs but not really fuel. I thought maybe water go in the fuel rail when whoever cleaned it. So I get this dumb *** idea to just dump some fuel into the IM. Well more fuel than I wanted got into there, and when it cranked a huge back fire lit off and the engine seized because of all the fuel in the chamber. I pulled the plugs cranked the motor by hand and a shitload of fuel shot out of #4. put the plugs back in and went to crank it over and this hideous sound is coming from around the flywheel area. Sounded like the flywheel was grinding. I figured I fucked something up. So we pulled the engine.
Today I tore it down, and it looks fine the #4 rod bearing is marred up, but I don’t see anything wrong, everything turns freely. My buddy took the starter to the parts store and it tested fine. I’m stumped. And ideas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">LoL. sorry I dont mean to be a dick but, the way u explained this was ****** hilarious.</TD></TR></TABLE>
i dont see how a backfire in the intake mani would make u spin a bearing
what do the teeth on the flywheel/starter look like
and was it runnin when u heard the noise or cranking over?
r the injectors pluged?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">please tell me someone had a camera when u decided to pour gas into the intake manifold and start it?</TD></TR></TABLE>
we do this all the time on our 800+ hp race car. no problems yet. just easier starts........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
we do this all the time on our 800+ hp race car. no problems yet. just easier starts........</TD></TR></TABLE>
I had to do this with my 67 firebird. When you're stuck at the gas station and diagnosing a bad fuel pump, a mountain dew bottle filled with gas is a good stress-reliever.
If it backfired, that would maybe say the cam or ignition timing is off, or the valves need adjustment big-time.
its ok dont feel to bad i managed to put my buddies head gasket on the wrong way last night and yes the oil was flowing out the back beetween the head and block like a river. i have always heard of people doing this but i had done tons of motors and switched out just as many heads i figured haha that will never happen to me but i guess we all make mistakes. and another shitty part was somehow my friend when we got it all fixed at like 4 am managed to stick the dizzys teeth into the cam backwards and being 180 degrees out made it jump timing while trying to start it but i re-set the TDC and moved the dizzy..... when u got a guy like me running on no sleep and a couple high buddies trying to swap heads somethings bound to F up but it runs awsome now and it moves like a raped ape now. so dont feel to bad WE ALL MESS UP HAHAHA GL
is this car even turbo'd? why is it in the f/i forum? lol
i hope you didn't blow the ringlands flooding the motor like that. i would check the tbelt and make sure everything is to tdc.
Ok ripped the motor apart to check for all the fucked up things that hydraulicing an engine can cause. Didn’t find any thing but a fucked rod bearing. I doubt that it was caused by aforementioned mistake, but replaced it while I had the engine apart. Turned out to be the starter making that noise. And the fitting to the fuel rail was the wrong one cut off the fuel. Thanks go out to Larry for stopping by and giving a hand!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic »</TD></TR><TR><TD CLASS="quote">its ok dont feel to bad i managed to put my buddies head gasket on the wrong way last night and yes the oil was flowing out the back beetween the head and block like a river. i have always heard of people doing this but i had done tons of motors and switched out just as many heads i figured haha that will never happen to me but i guess we all make mistakes. and another shitty part was somehow my friend when we got it all fixed at like 4 am managed to stick the dizzys teeth into the cam backwards and being 180 degrees out made it jump timing while trying to start it but i re-set the TDC and moved the dizzy..... when u got a guy like me running on no sleep and a couple high buddies trying to swap heads somethings bound to F up but it runs awsome now and it moves like a raped ape now. so dont feel to bad WE ALL MESS UP HAHAHA GL </TD></TR></TABLE>
damn reminds me of when i was helping a friend change his headgasket not too long ago. We forgot to jb weld shut the air injection holes on his new intake manifold so we had to pull it back off the engine. When we did that we neglected to pull the coolant line off of the manifold that runs near the #4 cylinder. Long story short coolant poured into the #4 cylinder, we didn't notice it and voila bent rod
ya even the best of us make mistakes. i still cant belive i put the gasket in wrong i have changed quite a few heads and built a few motors so and have read all sorts of posts on here about guys putting them on wrong so i figured i was safe and would never do that well i was wrong.
97civic07gsxr
19
Feb 24, 2009 05:20 PM
MoogieBoogie
Apr 24, 2004 01:49 PM
civicracer1993
15
Mar 20, 2003 08:29 PM
