valve cover ventilation "problem?"
Old Jul 16, 2006 | 03:38 PM
RaCk's Avatar
Default valve cover ventilation "problem?"
I was wondering.
The "tap" on the valvecover that goes to the induction stuff. shouldnt that be blowing instead of sucking?
On my CRX Vtec (illustrated picture is from my old Eg6) this tap actually sucks air.
Red marks the spot.
Old Jul 16, 2006 | 05:13 PM
1990si's Avatar
Default Re: valve cover ventilation "problem?" (RaCk)
no, if it blew air out, it would not be connected to the intake.
Old Jul 16, 2006 | 05:17 PM
Zaakro's Avatar
Default Re: valve cover ventilation "problem?" (1990si)
wouldnt it spray oil out also?
Old Jul 16, 2006 | 05:25 PM
mrtoastyjr's Avatar
Default Re: valve cover ventilation "problem?" (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt it spray oil out also?</TD></TR></TABLE>
yes
its supposed to suck. the air travels from the intake through the black hose into the valve cover, though the crank case, into that black box on the back of the block, up the black hose that is connected to the pcv valve, and into the intake mani
Old Jul 16, 2006 | 08:31 PM
La EF-8's Avatar
I just checked mine is sucking air
Old Jul 16, 2006 | 08:40 PM
rayzian's Avatar
Default Re: valve cover ventilation "problem?" (La EF-8)
weird.. mine blows... hot air
Old Jul 16, 2006 | 08:42 PM
1990si's Avatar
pry just feeling the heat from the motor, not actual air flow
Old Jul 16, 2006 | 08:43 PM
Kill_Roy's Avatar
Default Re: (1990si)
mine used to blow oil all over the firewall, but then again every ringland was toast
Old Jul 17, 2006 | 01:59 AM
RaCk's Avatar
So, Its nothing wrong.
Good to hear. Im mounting a filter on it. Im not having it blowing crap back into my engine.
Old Jul 17, 2006 | 03:33 AM
mrtoastyjr's Avatar
Default Re: valve cover ventilation "problem?" (rayzian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian &raquo;</TD></TR><TR><TD CLASS="quote">weird.. mine blows... hot air</TD></TR></TABLE>
bad rings
Old Jul 17, 2006 | 03:49 PM
rayzian's Avatar
Default Re: valve cover ventilation "problem?" (mrtoastyjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">bad rings</TD></TR></TABLE>
Really? Damn... I'm going to have to rebuild it then and replace all the rings? Is it worth it to do on a d15b2? I guess I'll wait until I can grab an MPFI manifold
Old Jul 17, 2006 | 03:53 PM
Tyson's Avatar
at idle and normal rpms, it should be sucking air into the valve cover.
thats because air is being sucked out of the engine at the crankcase through the PCV and vacuum from the IM.
if there is a lot of blow by, because of bad rings or at WOT, then both the valve cover and crankcase will both that blow by out of the engine.
EJ8 GSR-T
Oct 26, 2004 07:57 PM
JimmyAtlantis
13
Dec 26, 2003 12:24 PM
Ivan
Jun 27, 2003 07:25 AM
Ivan
Jun 27, 2003 04:37 AM
Turtle
Apr 1, 2002 06:27 AM
