Recommendation for one 12" for 1.25 cu. foot ported box
Old Jul 16, 2006 | 02:57 PM
Utilitarian's Avatar
Default Recommendation for one 12" for 1.25 cu. foot ported box
I don't really want to drop more than around $150 (ebay or store bought). I've been checking out the dvc Solobaric's on ebay, but was hoping for a recommendation or two before I buy one.
I'm not adverse to buying a smaller name brand than Kicker or JL just as long as sound quality is decent.
The sub would be installed in a pre-fab Q-logic box going into my '97 ITR.
thanks!
Matt
Old Jul 16, 2006 | 03:10 PM
mrdeadman's Avatar
They let me pick
Default Re: Recommendation for one 12" for 1.25 cu. foot ported box (Utilitarian)
If you want a ported box you won't get that great of sound quality anyway. Why do you want a ported box?
Old Jul 16, 2006 | 09:10 PM
Skip01's Avatar
Default Re: Recommendation for one 12" for 1.25 cu. foot ported box (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">If you want a ported box you won't get that great of sound quality anyway. Why do you want a ported box?</TD></TR></TABLE>
Says who.
Properly built ported box can have the same SQ as a sealed box anytime.
Keyword is properly.
Might could find a Type R for around 150,gotta look a lil though.Some incredible output,and good SQ.
Or Kicker Comp VR,sound decent as well.
Old Jul 16, 2006 | 10:20 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Recommendation for one 12" for 1.25 cu. foot ported box (Skip01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 &raquo;</TD></TR><TR><TD CLASS="quote">
Says who.
Or Kicker Comp VR,sound decent as well.</TD></TR></TABLE>
Thank you, so much false info being said. Mr deadman please keep info like that off our boards. Everyone knows a ported box would be about 3db louder then a sealed box. A sealed box would be smaller then a ported. If you have space go ported. If you have space concern go sealed.
Old Jul 16, 2006 | 10:34 PM
02 accord's Avatar
Default Re: Recommendation for one 12" for 1.25 cu. foot ported box (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">If you have space go ported. If you have space concern go sealed.</TD></TR></TABLE>
Or you could go with a passive radiator. Advantages of a ported box in the space of a sealed one.
Old Jul 16, 2006 | 10:41 PM
Default Re: Recommendation for one 12" for 1.25 cu. foot ported box (02 accord)
yea, but to much of a pain to build, and the cost. I would not waste my time on building on of theses. But infinity makes good one thou. But You won't in my imo get the same sound as a good built ported and sealed box. Don't get me wrong you can come close.
Old Jul 17, 2006 | 02:30 AM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">yea, but to much of a pain to build</TD></TR></TABLE>
It's just like building a sealed box, except that you're sticking a PR (or two) in it too, so one (or two) more round holes to cut. Big pain, I know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">But You won't in my imo get the same sound as a good built ported and sealed box. Don't get me wrong you can come close. </TD></TR></TABLE>
I know you won't get the same sound as a ported box; you will get better sound. A properly designed PR box will have the same response as a ported box, and will sound better, since there is no port to make noise. But then again, a properly designed ported box will sound just as good. As I said before, you can use a PR in a small (sealed size) box to get a response which would require a huge port (the port could take up as much room as the box) or a huge box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and the cost</TD></TR></TABLE>
It's all about compromises. The PR box (including PRs) would be the most expensive, but will yield ported box results in a sealed box size.
Old Jul 17, 2006 | 10:18 AM
mrdeadman's Avatar
They let me pick
Thank you, so much false info being said. Mr deadman please keep info like that off our boards. Everyone knows a ported box would be about 3db louder then a sealed box. A sealed box would be smaller then a ported. If you have space go ported. If you have space concern go sealed. </TD></TR></TABLE>
Not everyone cares about being louder. IMO a sealed box will sound better than a ported one any day. Everyone has their own ears, so don't tell me that I'm wrong just because you're partial to ported boxes.
Old Jul 17, 2006 | 11:25 AM
darkspector's Avatar
I'm pesonally a fan of sealed... smaller, easier to build.. and a tighter sounding
Old Jul 17, 2006 | 03:18 PM
Actually it's a box that can be ported or sealed.
It's just that you need higher power to really take advantage of a well-built sealed box. I'm only running around 300 rms.
Old Jul 17, 2006 | 04:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Actually it's a box that can be ported or sealed.
If your sub rms is 300, your not going to go above that if the box was ported or not, Ported you can go a lil lower then rms. same with sealed too, but it will sound better if closer to the rms.
Old Jul 17, 2006 | 04:42 PM
fcm's Avatar
fcm
Old Fart
Do you have a lonk to the eBay Solobarics, if they are a comp VR first thay are a 400W sub and min. recommended vented box is 1.75 cuft + port volume, and it is a big port, min. sealed is 1 cuft.
If you go with this sub, I would use up the extra .25 cuft with bracing for that pre-built Q-logic. [in my constitutionally protected opinion] POS box, and do a sealed box.
If you are just looking to get bass into the car as easily and inexpensively, find a sub that is 300W RMS and will work in a 1.25 cuft, like a JL Audio 12W3v3, [-2 if the amp is stable at 2 ohms] min. sealed box volume is 1.25 cuft. 94
FK00GSR
Audio / Security / Video
May 18, 2005 08:01 AM
civic_speed99
Aug 16, 2004 07:05 PM
honda95civic
Jul 24, 2004 07:09 AM
loki2323
Dec 18, 2002 09:09 AM
GoLowDrew
Jul 28, 2001 09:52 AM
