USDM Headlights and DRL running lights...
Has anybody successfully done the DRL conversion on USDM headlights?
I just got the Insight DRL module and hooked it up.
Everything was wired to the High beams, but only the Low beams came on.
I heard somewhere that USDM lights share the same ground (Hi and Lo beams.)
Is there anyway to do this?
Daytime-Running lights on USDM highbeams?
Any help is welcomed.
Just wondering if you ever got this figured out...I am trying to do the same thing. Where did you get the module from? Is that all that's needed?
DIY DRL's
http://www.team-integra.net/fo...earch
USDM headlights and DRL Running lights...
Canadian Daytime Running Lights (DRL) Pics?
https://honda-tech.com/zerothread?id=653786
Does anyone know a good place to find the OEM relay for the high beams so they are reduced brightness? Will any Honda ones work for it? I have been searching but so far all of the info I have found has been regarding trying to make something similar work...
fms1day
Jun 19, 2006 12:57 AM
