LS SWAP NO START - Code 4 - HELP -
Old Jul 15, 2006 | 05:38 PM
psycho.chicken's Avatar
Default LS SWAP NO START - Code 4 - HELP -
OK... ONLY code i get is 4 short blips...
One blip on key.. pause 4 quick blips/flashes...
I searched and found "replace distributor"
Since we just did the swap.. and follwoed wiring carefully...
Should i just replace teh dizzy.. or is there somethign we might of screded up?
PLEASE HELP dont want to buy a OBD0 dizzy unless i need to...
89 hatch DX to MPFI with 90/91 LS B18A1
Old Jul 15, 2006 | 05:42 PM
Default Re: LS SWAP NO START - Code 4 - HELP - (psycho.chicken)
OH
It does turn over....
Was so ticked i didnt test for spark...
Could I be 180 degrees off on the dizzy and have this problem
Old Jul 15, 2006 | 06:39 PM
jackinthetrunk's Avatar
you cannot be 180 off on the dizzy because it only fits one way. You really need to check everything on the car. Mainly check if all the injectors are getting power and if the fuel pump is priming. Check all the fuses and check for spark.
Old Jul 16, 2006 | 08:39 AM
what else could it be...
if it has a code for it can still run correct?
brenden747
Apr 7, 2013 03:33 PM
ketchup214
Apr 17, 2010 03:03 PM
jdm206
May 15, 2007 12:00 AM
Dr.Octagon
10
Feb 15, 2006 04:18 PM
ham
21
Jun 14, 2004 10:51 AM
