Car wont start, Wierd gas smell. Ecu code 43. Searched :/
Old Jul 15, 2006 | 04:18 PM
h22HatchEG's Avatar
Default Car wont start, Wierd gas smell. Ecu code 43. Searched :/
Well, my 90 Gs with b18b swap was running good for a while. Then last week i drove and got a horrid RAW gas smell in my car and was getting realy crappy mileage. I checked injectors, seals, fpr line. Everything except my hardline.
Well, i went to start her up to check fuel pressure and it would run for a few seconds then just die. I checked the ecu code and it was throwing a code 43. Which i know is fuel delivery. But my question is. Should i replace my fuel pump? and also where should i check my fuel hard line? Also could it be my fuel pressure regulator?
Thanks
Old Jul 15, 2006 | 05:52 PM
lsvtek's Avatar
Default Re: Car wont start, Wierd gas smell. Ecu code 43. Searched :/ (h22HatchEG)
mayb the fuel line is clogged, or the fuel filter is bad, try changin the fuel filter
ahtublao
29
Feb 23, 2010 08:21 PM
frizzle
Jan 23, 2010 09:35 PM
CorrodeONE
Feb 2, 2009 10:02 PM
thatnikkashoD
Feb 23, 2008 08:54 PM
Mikex25
Oct 24, 2001 07:32 PM
