Oil Squirters?
Old Jul 15, 2006 | 03:41 PM
foam's Avatar
Default Oil Squirters?
My friend is trying to put together my gsr block and while putting on the oil squirters I guess they hit the crank? The guy I bought my oil squirters on HT from said they were GSR but I guess they aren't? Do only GSR oil squirters work?
Old Jul 15, 2006 | 06:09 PM
qfast817's Avatar
Default Re: Oil Squirters? (foam)
well i had to weld mine up, they would hit the pistons
Old Jul 15, 2006 | 11:57 PM
foam's Avatar
I wanna use them though.
Old Jul 16, 2006 | 07:27 AM
qfast817's Avatar
Default Re: (foam)
i guess you could try bending them alil to see if it works
Old Jul 16, 2006 | 10:26 AM
foam's Avatar
Are B Series squirters interchangeable?
Old Jul 16, 2006 | 11:28 AM
foam's Avatar
Also is there another name for these? I called 2 Acura's up and both of them had no clue what I was talking about.
Old Jul 16, 2006 | 07:47 PM
qfast817's Avatar
Default Re: (foam)
http://www.acuraoemparts.com/d...ch=no
numkber 14 aka oil jet
Old Jul 16, 2006 | 08:11 PM
foam's Avatar
thanks a lot
Old Jul 17, 2006 | 01:50 AM
ARACER25's Avatar
Default Re: (foam)
the oil jet or squirters whatever you want to call them are the same and there is a dimple so they onlu go in one way. There is only one part number for them and yes they are interchangable. Now when I took my motor apart to change pistons and rods i did not mark which one came from which cylinder because they are all the same right? well when I put it back together the crank hit two of them and actually broke one. I got new ones and bent they ever so slightly and carefully to get them to clear the crank.
Old Jul 17, 2006 | 01:17 PM
foam's Avatar
I might just block them off. Is that okay for DD? I don't race or anything.
Old Jul 17, 2006 | 03:52 PM
NJIN BUILDR's Avatar
Default Re: (foam)
http://www.accountwizard.com/c...d=321
Golden Eagle sells some nice squirter blockoff plugs.
Brett
Jan 21, 2010 04:23 PM
garyc17
Feb 12, 2006 07:37 PM
91 RS Beater
Dec 9, 2002 06:40 PM
CM-R
May 28, 2002 07:49 AM
