e55 retrofit Help- Can't get bulb to stay in socket
Old Jul 15, 2006 | 03:20 PM
Zion-I's Avatar
Default e55 retrofit Help- Can't get bulb to stay in socket
I'm having a problem with keeping the bulb inside the projector. I've spent hours trying to fix it so that the little metal spring "V" piece would secure the bulb in place. The bulb still wobbles around after i attach the metal piece and is easily removed. I cant figure out what I'm doing wrong. Is the metal piece suppose to latch anywhere else other than the grooves on the back of the projector?
Old Jul 15, 2006 | 03:30 PM
i-VTEC_do_you's Avatar
Default Re: e55 retrofit Help- Can't get bulb to stay in socket (Justa_Old_DC2)
try bending them a little so there is more tension on the bulb
Old Jul 15, 2006 | 03:43 PM
Zion-I's Avatar
Default Re: e55 retrofit Help- Can't get bulb to stay in socket (i-VTEC_do_you)
Gave that a try too, doesnt seem to be working for me. The bulb is still able to wiggle out.
Old Jul 15, 2006 | 03:56 PM
is it possible the bulb is upside douwn? There seems to be two tabs on the bulb that could possibly need to catch in the bends of the clip.
Old Jul 15, 2006 | 04:03 PM
Zion-I's Avatar
i dont think the bulb is upside down because the bulb has grooves that meet the projector so that it lines up right. It just seems that the V clip doesnt hold it tight enough for the bulb not to move. It's loose enough that if i drove the car, the beam would shake up and down or even possibly have the bulb come out of the socket.
Old Jul 15, 2006 | 04:07 PM
I'm really working my brain, i want to help but i'm not an HID conversion expert
any pics of bulb and projector separate
Old Jul 15, 2006 | 04:09 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
isn't there supposed to be a circular metal spring that goes in between the bulb and the socket for tension? does the other side work fine? do they both look the same (parts wise)?
Old Jul 15, 2006 | 04:17 PM
Zion-I's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
Yea I know, I appreciate it. Theres no spring in between the bulb and the socket. The bulb has little grooves that go into the socket. It doesnt twist in, it just sits in the socket. The V spring clip is suppose to keep the bulb in place. Both sides work the same way. I've been switching clips and bulbs between both headlights. Can't seem to get either one to stay secure. I think that the V clip is suppose to provide the tension on the bulb.
Old Jul 15, 2006 | 07:37 PM
Zion-I's Avatar
Default Re: (Justa_Old_DC2)
nvm figured it out. I kept bending the v clip until it fit the bulb in snug and then reinforced it with some zip ties. Thanks HT. O BTW. What a difference HID makes... Its day and night.
Old Jul 16, 2006 | 09:24 PM
zip ties FTW! i love ghetto fixes when they work right.
Old Jul 16, 2006 | 09:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
FTL. Not on an HID projector, ghetto fixes are just that, ghetto. It needs to be done right.
You're not just sticking those wire retainer clips in there are you? The wire clip is supposed to be attached to the bulb holder like a hinge, and it's supposed to swing down and go into those slots, pressing and holding the bulb in place. If you're just taking the clips on and off and holding them in your hand, then it's incorrect.
You can see here where the wire clip sticks out along the bottom, and at the top it's attached in a hinge-like fashion:
https://honda-tech.com/zerothread?id=891136
The bulb should be rock solid when the clip is swung down over the bulb and locked into place, not moving around at all.
xkrntamax
Jul 31, 2006 08:22 AM
LSBeast
Dec 30, 2005 01:30 PM
exile29
Sep 10, 2005 09:51 AM
defaced
Apr 8, 2004 08:22 PM
Spooled1.6L
Feb 9, 2004 10:52 AM
