eg power door lock wiring
well i have oem eg power door locks that i put in my hatchback. i got the door harness all in and the problem is i don't have the under the dash harness. so im trying to self wire it up. whats left are the 2 green wires for the door lock switch that also goes to the door lock control unit. and 1 white wire coming from the door lock control unit. im trying to figure out what am i sapose to do with those 3 wires?
yea its a civic 92 - 95 but mines is a hatch i already put the power windows in and now im figuring out the power door locks. i have all the wires ran 2 wires to the passenger door lock too and now im left with 3 wires. the 2 wires from the lock/unlock switch which also leads to the door lock control unit and a white wire coming for the door lock control unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Haven't we gone through this before, fcm???
An EG is a 92-95 Civic.
</TD></TR></TABLE> Yes, but I have brain damage, so I have an excuse, it would be so much easier if everyone would just give a MM&Y.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myronwong »</TD></TR><TR><TD CLASS="quote">yea its a civic 92 - 95 but mines is a hatch i already put the power windows in and now im figuring out the power door locks. i have all the wires ran 2 wires to the passenger door lock too and now im left with 3 wires. the 2 wires from the lock/unlock switch which also leads to the door lock control unit and a white wire coming for the door lock control unit.</TD></TR></TABLE> Sorry only have wiring schematics for g2s and 96-98 Civics and 94-98 Integras.
The diagrams do not shoe any green or white wires, however, on both the Civic and teg it shows a white/green from the "D/L Control Unit" going to the fuse box, 20A fuse, and a green/white and a green/orange going from the drivers switch to the "D/L Control Unit" and the security/key-less module.
What color are the 2 leads going to the pass. door? The Civic diagram I have shows a yellow/red and a white/red.
94
94
You need a control module. You can use any alarm or keyless entry model. In fact I recommend it.
Basically two of those wires rest at ground, and the other is a constant 12v. When you hit the switch, it breifly touches that constant 12v to one of the wires.
Some day I'm going to send fcm some EG wiring schematics. I don't understand how he has all the other hondas, but not the most common of them all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Some day I'm going to send fcm some EG wiring schematics. I don't understand how he has all the other hondas, but not the most common of them all.</TD></TR></TABLE> LOL, I own a 94 Teg, the Haynes manual, [12021] I have is is for 96-98 Civics and 94-98 Integras, the only other one I have is for 90-93 Legends and 90-93 Integras, [I spend a lot of time on g2ic,com also.
Now you understand.
But your right I see the "EG" pop up all the time. so I will go out and get a manual for it as it seems to have a diff. wire color code for a lot of things.
94
Now you understand.
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">You need a control module. You can use any alarm or keyless entry model. In fact I recommend it.</TD></TR></TABLE> I think he said he had the module, I cant see the system in the "EG" being that much diff. then the 96-98 Civic, [except for wire colors maybe] on a 96-98 it shows a green/white, [lock] and a green/orange, [unlock] as the neg.(-) input triggers to the module from the drivers door lock switch and from the oem alarm/key-less entry and the white/green as the power for the module, he says that on the "EG" module he is left with a white and 2 greens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myronwong »</TD></TR><TR><TD CLASS="quote">yea its those wires so the green ones go no where?</TD></TR></TABLE> As I have said I can't be sure, because I do not have a wiring diagram for the "EG", [only the LX, HX (USA) and the EX, SI (CDN)] and it shows a white/GREEN, [power for module] and a green/WHITE, [lock input to module] and green/orange, [unlock input to module].
When you say "yea it's those wires" do you mean that they are green and have the white and orange tracers on them?
94
94
GESEKI
Jan 28, 2013 04:46 AM
