Exhaust Spring Bolts
Old Jul 14, 2006 | 08:05 PM
Floored's Avatar
Default Exhaust Spring Bolts
I just finished installing my hks sport exhaust and during the install I removed the cat and installed new spring bolts between the cat and the exhaust manifold. There are no exhaust leaks or anything, but when I shift sometimes I hear a squeak and I think it is the spring bolts. The nut on the end of the spring bolt didn't seem to be tight until the spring was fully compressed. So my question is can I loosen the bolt and not have to worry about my exhaust falling off down the line? BTW these are the advance auto spring bolts.
Old Jul 14, 2006 | 08:08 PM
JapJunkie's Avatar
Default Re: Exhaust Spring Bolts (Floored)
Matters how much you loosen. I think it might be alright, if not too loose, since the spring applies pressure to the nut and bolt.
Old Jul 15, 2006 | 04:10 AM
Floored's Avatar
Default Re: Exhaust Spring Bolts (JapJunkie)
Yeah good point, I will just loosen them up a little and check on them in a week to see if they are still in the same position
Old Jul 15, 2006 | 04:59 AM
civicandy's Avatar
i think you want it to be as tight as possible w/o leaking. i've always tightend them completely and never had any problems
Old Jul 15, 2006 | 05:30 AM
Floored's Avatar
Default Re: Exhaust Spring Bolts (civicandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">i think you want it to be as tight as possible w/o leaking. i've always tightend them completely and never had any problems</TD></TR></TABLE>
Springs fully compressed though
Old Jul 15, 2006 | 06:05 AM
fireant's Avatar
Do you have the rounded flange gasket on your header? It looks like a sliced bagel made of fibrous metal.
I ask because not having one will make that connection point squeak.
Old Jul 15, 2006 | 06:52 AM
Floored's Avatar
Default Re: Exhaust Spring Bolts (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Do you have the rounded flange gasket on your header? It looks like a sliced bagel made of fibrous metal.
I ask because not having one will make that connection point squeak.</TD></TR></TABLE>
Yes I made sure to put one on, it isnt sitting flush (very small gap) between the exhaust manifold and cat though, should it? I dont have a leak but man that slight squeak annoys me.
Old Jul 16, 2006 | 10:11 AM
Floored's Avatar
Well I looked at my exhaust more closely today and realized the squeak wasnt coming from the front but rather the rear. Turns out the heat shield near the gas tank was just rubbing a bit on the piping. So all is fixed
Old Jul 17, 2006 | 07:37 AM
civicandy's Avatar
now you can drive in silence
jdmark1
May 7, 2017 02:53 PM
huge230
Aug 23, 2007 12:11 PM
NegativeXero
Nov 23, 2006 04:51 PM
egzo04
Sep 30, 2005 06:44 PM
B00ST2nR
Mar 30, 2004 02:22 PM
