XTD or F1 which is better???
Need a clutch bad!!!
Which one is Better
1. F1 stage 3 http://cgi.ebay.com/ebaymotors...sting
2. XTD stage 3 http://cgi.ebay.com/ebaymotors...wItem
3. Exedy oem style http://cgi.ebay.com/ebaymotors...wItem
Anyone??
Modified by donaldmejr at 8:22 PM 7/14/2006
Which one is Better
Anyone??
Dont get a puck clutch unless you need it....If you have a stock motor or just small boltons just get a stock replacment or stage1....But you dont want no puck if you dont need it,,especially for a daily driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donaldmejr »</TD></TR><TR><TD CLASS="quote">Im just not wanting to change it for a long time</TD></TR></TABLE>
then just get a good quality oem replacement. a puck clutch will ruin your daily comfort in a bad way.
I got a xtd/aimco clutch and am satisfied with the quality, good clutch for the price, As stated earlier you dont want a puck style unless you need it just call up and ask for a stage 3 pressure plate and a stock organic disc, it will engage smoothly and have the same wear characteristics of a stock clutch but will have holding power from the upgraded pressure plate, thats what I did, that xtd/aimco guy also sells exedy, i used his xtd pressure plate with a stock exedy disc
his flywheels are also super cheap and good too I think $150 for a 8lb one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">I got a xtd/aimco clutch and am satisfied with the quality, good clutch for the price, As stated earlier you dont want a puck style unless you need it just call up and ask for a stage 3 pressure plate and a stock organic disc, it will engage smoothly and have the same wear characteristics of a stock clutch but will have holding power from the upgraded pressure plate, thats what I did, that xtd/aimco guy also sells exedy, i used his xtd pressure plate with a stock exedy disc
his flywheels are also super cheap and good too I think $150 for a 8lb one.</TD></TR></TABLE>
no need for an 8lb flywheel unless ur heavily modified, might hurt more than it helps.
his flywheels are also super cheap and good too I think $150 for a 8lb one.</TD></TR></TABLE>no need for an 8lb flywheel unless ur heavily modified, might hurt more than it helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX »</TD></TR><TR><TD CLASS="quote">
no need for an 8lb flywheel unless ur heavily modified, might hurt more than it helps.</TD></TR></TABLE>
How is that????
How is that????
dllnzek
Transmission & Drivetrain
Jul 18, 2012 09:16 AM
davidluko
Sep 4, 2006 10:42 PM
