Suspension setting....
Old Jul 14, 2006 | 07:34 AM
Valvola's Avatar
Default Suspension setting....
In this week I have finished the suspension setting of my R on balances.
At the end of the work with +- 20 liters of fuel the weight of my R was 1060kg and 1135kg with me onboard.
Now the front pads of my Tein flex works after 1 cm of excursion, for the rear dampers after 1,5cm.
At the end of settings we have put front toe -3mm rear toe -2mm; front camber -3 rear camber -2,5.
Here 3 bad pictures from my phone
This was NOT the last setting, (I wasn't onboard)
Old Jul 14, 2006 | 07:43 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: Suspension setting.... (Valvola)
sweet pics
GT3
Old Jul 14, 2006 | 05:55 PM
Willard's Avatar
Nice. ~2500 pounds with driver.
Will you be changing the toe settings soon?
The front and rear camber look good to go.
for getting the car corner weighted... and having it done correctly.
Longacre scales =
Here are my #'s (in pounds).
https://honda-tech.com/zerothread?id=1185665
Old Jul 14, 2006 | 07:12 PM
itr1244's Avatar
Default Re: Suspension setting.... (Willard)
man. i Soooooooo want to do that too
Old Jul 14, 2006 | 07:15 PM
white rocket's Avatar
Default Re: Suspension setting.... (itr1244)
I would love to corner weigh my car
Good job.
Old Jul 14, 2006 | 11:03 PM
Valvola's Avatar
Default Re: Suspension setting.... (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Will you be changing the toe settings soon?
I know that the toe is too open, but I usually use my R in a short track with many corners and I have to fight understeer....I 'll try, if I'll feel bad I' ll return to my old -2mm front -1mm rear
killer_Bseries
Suspension & Brakes
Jul 26, 2011 03:08 PM
L8APX
Mar 21, 2009 01:26 PM
FalkenSiR
Suspension & Brakes
Jun 6, 2006 11:06 AM
JunIntegra
Nov 17, 2004 11:49 AM
Silroan
May 23, 2004 06:13 PM
