Help, brake lights stay on after battery replacement.
Old Jul 14, 2006 | 07:10 AM
Kalokohan's Avatar
New User
Default Help, brake lights stay on after battery replacement.
Hey guys I'm new to the EF world. I just picked up a 90 HF with a dead battery. After I replaced the battery, I start the car and the brake lights come on without me even touching the brake pedal. Even after shutting the car off, both brake lights and 3rd brake light stays on. Any suggestions?
Old Jul 14, 2006 | 07:15 AM
crx_88_si's Avatar
check the switch at the top of the brake pedal, possible stuck, or still being depressed.
in most if not all cars, the car can be completely off w/ ign key out and the brake lights still work.
Old Jul 14, 2006 | 07:17 AM
Mr_CRX's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">check the switch at the top of the brake pedal, possible stuck, or still being depressed.
Yeah. There is a small round plastic piece on the brake pedal that pushes on the switch. I've had this plastic piece fall out before. had the same problem with the lights staying on.
Old Jul 14, 2006 | 07:34 AM
Kalokohan's Avatar
New User
Default Re: (Mr_CRX)
Thanks guys, I'll try that tonight!
Old Jul 14, 2006 | 08:06 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (Kalokohan)
Here is a pic of what to look for:
Old Jul 14, 2006 | 08:13 AM
Kalokohan's Avatar
New User
Default Re: (88DXCRX)
So it seems like that button may be stuck and I would just have to pull it out? What should I do to prevent it from getting stuck again?
Old Jul 14, 2006 | 10:50 AM
88DXCRX's Avatar
There is supposed to be a rubber piece there...
What happens is it rots and crumbles into pieces..
For a temporary fix,I stuck a bolt in the hole or some
tape a coin there..
The dealer should have the part in stock..
edjudy91
Honda Civic (2001 - 2005)
Mar 20, 2013 08:38 AM
brndnhlcmb
May 1, 2010 08:44 PM
gsrsuperman
13
Jul 21, 2008 10:20 AM
RanCRX
Jun 9, 2008 07:35 PM
LilLowEK
Jan 20, 2005 10:03 AM
