what causes the buzzing around the brake master cylinder??
Old Apr 20, 2002 | 07:01 PM
slimbo's Avatar
Default what causes the buzzing around the brake master cylinder??
I notice that every now and again, when i start the car up i will hear a buzzing for a few seconds around the master cylinder area... i can't think what it could be from?
i haven't noticed any problems *yet*. could it be something to do with the abs system??
TIA
Old Apr 20, 2002 | 07:13 PM
Jubba's Avatar
Default Re: what causes the buzzing around the brake master cylinder?? (slimbo)
you could be loosing preasure in your lines somehow and the sound you hear is that preasure be reaquired. is any of your fluid low? i'd look in all the common manuals for your car and see if they have a troubleshooting area for that specifically. i'd look for you, but i dont have any of mine on hand. when i'm home i'll check for you
Old Apr 20, 2002 | 08:18 PM
slimbo's Avatar
Default Re: what causes the buzzing around the brake master cylinder?? (Jubba)
thanx!
Old Apr 20, 2002 | 08:48 PM
sackdz's Avatar
Can you descibe the sound a little better? I know a several people, myself included, that does that just when starting up. It's the ABS unit cycling. You can feel it in the pedal a little bit.
Old Apr 22, 2002 | 04:00 AM
slimbo's Avatar
Default Re: what causes the buzzing around the brake master cylinder?? (sackdz)
Yeah i can feel it in the pedal.
my fluid level is fine and the brake doesn't get spongey or anything.
cud be the abs unit.
driali
Honda Civic (2006 - 2015)
Mar 28, 2018 10:13 PM
xiLLtegRax
Oct 20, 2005 12:35 PM
Honda_RN
Jun 14, 2003 07:46 PM
DMF
15
Feb 1, 2003 04:02 PM
