whats the biggest speaker size fitment for a 95 civic coupe?
Old Jul 13, 2006 | 08:24 PM
Manolo's Avatar
Default whats the biggest speaker size fitment for a 95 civic coupe?
i want to get components all around, front doors and rear panel. whats the biggest size that i should go for?
Old Jul 13, 2006 | 09:33 PM
bpr0422's Avatar
Default Re: whats the biggest speaker size fitment for a 95 civic coupe? (Manolo)
umm..
in stock enclosures...
u could just check http://www.crutchfield.com/S-QadIptFTCcJ/
in their veichle fitment guide...
also .. don't waste ur money's on components on the rear..
rear is just fill sound..
setup a good front stage, with a nice set of components, and an amp to power them
rears powered by the head, and a sub.
Old Jul 13, 2006 | 10:53 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
6.5 would fit all around. But you would need to make plates for the back.
Old Jul 14, 2006 | 04:37 PM
JSPECSIR's Avatar
Default Re: whats the biggest speaker size fitment for a 95 civic coupe? (wrx-killer-Sti eater)
http://www.hondaautomotivepart...EAKER
if you have an ex you should already have 6.5 in brackets all the way around if not you can get ex brackets if you dont want to make anythng.
Old Jul 24, 2006 | 10:04 PM
Syndacate's Avatar
in a coupe it'll fit 5 1/4 or 6 1/2's in the front but only 5 1/4's on the rear
Old Jul 25, 2006 | 06:04 AM
JSPECSIR's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">in a coupe it'll fit 5 1/4 or 6 1/2's in the front but only 5 1/4's on the rear</TD></TR></TABLE>that must be why my oversized 6 1/2s went right into those oem rear brackets in my wifes car.
it clearly states part 10, and 15 are 6.5 brackets.
Old Jul 25, 2006 | 06:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manolo &raquo;</TD></TR><TR><TD CLASS="quote">i want to get components all around, front doors and rear panel. whats the biggest size that i should go for?</TD></TR></TABLE> The stock speaker is a standard 6.5" speaker, [not to be confused with the newer over-sized 6.5" speakers].
A standard 6.5" speaker that has just under a 2" mounting depth will fit without mods, if the speakers mounting depth is more then 2" the back of the stock speaker housing, [front speakers] can be cut off, for extra depth, or a depth reducer, [spacer] can be used, if the speaker is extra deep., a combination of spacer and cutting the back off the stock housing will need to be done.
I will agree with bpr0422 <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote"> don't waste ur money's on components on the rear..
rear is just fill sound..</TD></TR></TABLE> Spend your money on a good set of front component speakers, get an amp for them, leave the stock ones in place for now and run them off the HUs internal amp.
If you want to replace the rears, get a set of mid-range/mid-bass drivers, [no tweeters] and get a 4ch amp.
Another thing to think about is the front speaker housings, for best possible sound out of whatever speakers you install in the doors you should replace the OEM plastic speaker housings with custom MDF housings, they can be made to fit just about any speaker up to 7". 94
lilmoody88
Audio / Security / Video
Apr 10, 2017 01:43 PM
thehiddencheese
Sep 29, 2015 07:48 AM
DonDinero
Honda Civic (2001 - 2005)
Jan 10, 2008 10:54 PM
itsJDMyo
16
Sep 18, 2003 03:02 PM
