My Wilwood caliper is leaking after install...trying to figure out why...
Old Jul 13, 2006 | 06:35 PM
preludepower's Avatar
Default My Wilwood caliper is leaking after install...trying to figure out why...
Ok, so I installed a wilwood big brake kit in my 92' civic hatch. Everything in the install went fairly smooth, except that I had to go out and buy spacers to make my wheel clear the caliper.
Anyways, now that everything is done, brakes are bled, there is a leak coming from the caliper, where the the fitting screws in on the back side. What the hell??
I tightened the fitting a little bit more, but obviously there comes a point where you risk stripping it.
My car is not running when I step on the brake pedal to test this. When it gets stiff after a pump or two, that's when you can see a very slow/small leak from the back side of the caliper.
Any ideas?
NH
Old Jul 13, 2006 | 08:18 PM
Default Re: My Wilwood caliper is leaking after install...trying to figure out why... (preludepower)
c'mon yall...this is my safety were talking about here!
Someone out there knows what I'm talking about...
Old Jul 13, 2006 | 08:24 PM
Kamin's Avatar
wait more than 2 hours before bumping, people arent at your beckoning call to aswer your questions 24/7
and did you forget to put the copper washer on between the line and the caliper?
Old Jul 13, 2006 | 08:40 PM
Default Re: My Wilwood caliper is leaking after install...trying to figure out why... (Kamin)
There were no copper washers included in the kit, and they don't say a thing about it in the directions.
the fittings are in there tight, and I don't understand why they won't hold pressure
Old Jul 13, 2006 | 08:45 PM
Kamin's Avatar
reuse your washer from the old brakes
ive never seen brakes without the washer. now i could be wrong, but i also could be right.
Old Jul 13, 2006 | 08:50 PM
Well, the fitting on the new wilwood caliper isn't a 'banjo' fitting.
you can see a pic of what I'm talking about at:
http://overboost.com/story.asp?id=527
the pics of the caliper are near the bottom of the page
Old Jul 14, 2006 | 12:33 AM
broketuner-Sol_Si's Avatar
Did you use teflon on the threads? I had a similar problem when I did my rear disc conversion. After doing a layer of telfon and new washers no problem.
Old Jul 16, 2006 | 03:58 PM
Ok, spoke to one of the tech guys at Wilwood...
You have tighten down the fittings until they're TIGHT...way more than handtight, or at least until you get the leak to stop.
So far they aren't leaking.
BIGef
Nov 19, 2012 11:28 PM
wgbm92
Oct 9, 2012 07:09 PM
Nisif
20
Sep 26, 2007 07:04 AM
civic_minded1987
Honda Civic (2001 - 2005)
Jul 14, 2006 04:38 PM
wantmorepower
11
Dec 13, 2002 10:27 PM
