fuek pressure
i'm gettin mixed results when searching. i just got a aem fuel ral and holley fpr on my car. without the vaccum line hooked up it reads 41psi, but with it plugged, its about 30psi. am i suppose to set it to 40psi with or without the vaccum plug because its running bad right now. what is the proper way to adjust the fuel pressure?
well shes got about every bolt on you can put on a b16 now, minusing cams. I'm about to boost her so thats why i upgraded and the rail was free from a good friend of mine. but since when was this thread about why did i buy sumthing? should'nt it be more like how do i change my fuel pressure?
if thats how you take it then fine.
its like this, right now you dont need a step in fuel pressure. a stock rail and reg can flow enough for 400 whp. you are adding fuel to an engine that doesnt need it thats why i ask. oh and btw the clamp on holley fpr, just like the bm command flow and vortech fuel commander, are junk. had one. never held fuel pressure at all.
so before you go off judging why people ask you questions think about it. i asked you a vaild question. if you want to run pig rich for no reason, go ahead. thats fine with me.
this is why i only post every now and then in this forum. this forum has gone to crap. ill stay in dr/fi from now on.
sorri if i took it the wrong way, every time sumone buy sumthing for their car peple flame them and act like they should'nt get it. thanks for the info, i'll probali be putting the stock fpr back on and keep the rail for now.
well i tryed setting it to 44 psi with hose off, but when yu put the hose back on it drops to 31 or 32 psi. any ideas here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">do you have any mods to necessitate a rail and reg upgrade? just asking because a stock rail and reg can get you to 400 wheel.</TD></TR></TABLE>
or 500hp
That guy knows his **** ^^^^^^^^^^^
or 500hp
jdmhondak9
38
Jul 28, 2013 10:24 AM
boostinscrappy
Honda S2000
Jun 30, 2013 06:05 PM
