engine build need advice on part matching
Old Jul 13, 2006 | 06:05 PM
i-VTEC_do_you's Avatar
Default engine build need advice on part matching
I am doing a LS VTEC swap to my VTEC swaped DA. Currently it is powered by a B16A OBD0. I already have an LS short block mildly built, (GSR pistons, shaved LS rods, balanced and blue printed crank), but with no water pump, crank pulley, tensioner, t-belt or timing covers.
Parts at my disposal
-B16A VTEC water pump (new)
-B16A oil pump
-hope to use B16A t-belt (new)
-I have GSR t-belt and timing cover if that helps?
What parts do I need to mix and match *together* to make this work?
Old Jul 14, 2006 | 09:52 AM
Default Re: engine build need advice on part matching (i-VTEC_do_you)
bump
SIef9
Dec 10, 2010 11:46 AM
cyrock
Aug 11, 2004 01:05 PM
paulzy
Jun 27, 2001 11:06 AM
