B16a2 head mated to a B20 block
Old Jul 13, 2006 | 01:26 PM
MW325's Avatar
Default B16a2 head mated to a B20 block
Yes...I recently bought a '99 Civic Si. I was thinking of taking my heads and mating them to a B20 block. What kind of #'s do you think I will be getting then? And even if then...I will have to be buying all the internals to run it. Would I get much bigger of a difference than running my B16a2?
Old Jul 13, 2006 | 01:30 PM
philosofy1's Avatar
Default Re: B16a2 head mated to a B20 block (MW325)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MW325 &raquo;</TD></TR><TR><TD CLASS="quote">Yes...I recently bought a '99 Civic Si. I was thinking of taking my heads and mating them to a B20 block. What kind of #'s do you think I will be getting then? And even if then...I will have to be buying all the internals to run it. Would I get much bigger of a difference than running my B16a2?</TD></TR></TABLE>
all you will need is the block. take out your internals from the b16 and put them into the b20. as far as putting the head on the block it will work with some work.
for the numbers of hp, don't know. might want to search for that one.
G2 Speed's Avatar
search
and you will get alot more torque
b16a2 lacks torque.... , I think you have like 111lb's
Old Jul 13, 2006 | 01:56 PM
Chris Benoit's Avatar
Default Re: B16a2 head mated to a B20 block (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">all you will need is the block. take out your internals from the b16 and put them into the b20. as far as putting the head on the block it will work with some work.
for the numbers of hp, don't know. might want to search for that one. </TD></TR></TABLE>
b16 internals will not fit in a b20
Old Jul 13, 2006 | 02:02 PM
philosofy1's Avatar
Default Re: B16a2 head mated to a B20 block (John Cutter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John Cutter &raquo;</TD></TR><TR><TD CLASS="quote">
b16 internals will not fit in a b20</TD></TR></TABLE>
sorry i was thinking more like the pistons only. was in a rush when i posted.
Old Jul 13, 2006 | 02:19 PM
are you saying the pistons will fit? they won't, the b20 has an 84mm bore
Old Jul 13, 2006 | 02:24 PM
philosofy1's Avatar
your right, sorry. you see there was an article in honda tuning referring to this topic. yes your right they do have a 84mm sized piston. i'm totally wrong, sorry man
it's not my fault if forgot the details of the article, it's my brains fault. LOL
Old Jul 13, 2006 | 02:25 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">your right, sorry. you see there was an article in honda tuning referring to this topic. yes your right they do have a 84mm sized piston. i'm totally wrong, sorry man
it's not my fault if forgot the details of the article, it's my brains fault. LOL </TD></TR></TABLE>
hahahah lol
Old Jul 13, 2006 | 02:33 PM
Default Re: B16a2 head mated to a B20 block (G2 Speed)
dude, no need to apologize, it's cool.
Old Jul 13, 2006 | 02:37 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
hahahah lol </TD></TR></TABLE>
hey i can admit when i'm wrong, i don't know every single thing about honda's.
just alot.
Old Jul 13, 2006 | 02:42 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">hey i can admit when i'm wrong, i don't know every single thing about honda's.
just alot. </TD></TR></TABLE>
you weren't "wrong" as in you don't know what your doing, you just mixed up lol
Old Jul 13, 2006 | 10:04 PM
MW325's Avatar
So in order to safely mate the two...I would only need the B20 block...my B16a2 head...and aftermarket internals? I read an article in Honda Tuning saying that I would need to drill holes in the heads to accept the block. HT said this would be a great setup for still under $1000. I have this and more...just waiting to decide what to do with it. I would like my Si to be able to use as a daily driver. I recently backed into a suburban which will cost me $475 to order a new trunk lid w/ hinges painted.
Old Jul 14, 2006 | 09:08 AM
Go in to the all motor forum. There is a great write up about ls/b20vtecs.
JDMroyEG5turbo
Mar 13, 2006 01:18 PM
RACEPAK
Dec 12, 2005 01:13 PM
SuperImport
Mar 18, 2005 01:01 PM
bsemeyn
Sep 30, 2003 06:15 AM
ITR 01-581
Nov 30, 2002 07:14 PM
